Looking for an engine builder/tuner in SoCal - Pontiac GTO Forum
post #1 of 4 (permalink) Old 04-17-2013, 03:18 PM Thread Starter
I have a 65 GTO. 400 bored .060. Looking for an engine builder/tuner in SoCal. Hoping someone can point me in the right direction.
MBlackmer22 is offline
post #2 of 4 (permalink) Old 04-19-2013, 12:18 PM
Does it have to be SoCal? The best in the business is in Virginia...
What all do you need done?
post #3 of 4 (permalink) Old 04-23-2013, 12:08 PM
Quoted: 117 Post(s)
Also, if your 400 is bored .060 and needs a rebuild, you will need to source another block if machine work is required. .060" is pretty much the "last cut" on these blocks unless you want to run sleeves in each hole ($$$). Get on line and check it out. I think HO is in LA, and several others.
post #4 of 4 (permalink) Old 04-25-2013, 11:25 AM
Indetrucks's Avatar
Where in So. Cal?
You can give Hot Rod Performance a call (in Torrance)
Mark has owned and operated that speed shop for YEARS.
Indetrucks is offline
Proud New 67 Owner, first time builder bigjake88 Member Introductions 4 01-24-2013 08:54 PM
Who is the best pontiac engine builder? nmiller5000 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 12 04-17-2012 12:51 PM
Good Trans Builder SlackerCracker Drive train, suspension, alignment and brakes. 2 05-26-2011 09:19 PM
Engine tuner in IL jonw65 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 05-27-2010 09:15 PM
Engine Tuner Q's Shorty29 2004-2006 GTO General Discussion 8 02-02-2010 09:59 PM
