Loses Power - Pontiac GTO Forum
 1Likes
  • 1 Post By BLK69JUDGE
post #1 of 2 (permalink) Old 09-24-2018, 01:46 PM Thread Starter
Loses Power
I have a 1968 GTO with the stock 400/4-speed with the Rochester Quadrajet Carburetor. It's an occasional driver. When I took it out a week ago it started fine but as I was driving it lost power/regained, lost power/regained....sort of like letting up on the accelerator and then pressing it down again. I figured I had some sort of a fuel delivery problem and since (as far as I know) the fuel pump was original I replaced it. The car did the same thing, so I removed the inline fuel filter that I installed some time ago AND the filter in the carburetor housing. It still does the same thing. It will idle fine for a while and then the rpm's will drop almost to a stall, then it recovers, then it happens again in another minute or two. Just for giggles I checked the dwell and timing and both are dead on. What am I missing here? Is this a potential problem with the carb? The only other thing I can think of is a) that little mesh sock on the intake in the tank has collapsed or b) the short fuel hose that comes out of the tank has somehow shifted and crimped. Or I have another problem altogether.
Any and all thoughts are appreciated. Thanks!
Wilma is offline
post #2 of 2 (permalink) Old 09-24-2018, 03:46 PM
BLK69JUDGE's Avatar
Quoted: 62 Post(s)
Hello
time for 5' of gas line and a gas can to the fuel pump
they can suck air also at the tank outlet hose
start simple get those filters back in
use 2 tw0 II TWO wrenches at the carb
make sure you have a good correct nylon washer between nut n carb ..dont overtighten
deanhickey likes this.
BLK69JUDGE is online now
Power Windows, Power Locks, Seat Belts, Power Rear View Mirror, Back Speaker Location GQUINCOCES 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 2 01-03-2009 07:18 PM
Corvette loses control TORNATIC!! Audio & Video Clips 2 03-03-2006 09:14 AM
Honda CBR600 RR loses to a 300 BHP car. Believe it!! 6QTS11OZ Audio & Video Clips 82 11-22-2005 01:05 PM
Newb Loses to C5?? 70sFlashback Racing and Kill Forum 12 07-18-2005 06:02 PM
