Manual turn - Pontiac GTO Forum
post #1 of 6 (permalink) Old 05-02-2019, 06:38 AM Thread Starter
MidnightAuto's Avatar
Manual turn
I know this is a silly question, but if I am manually turning the crank with the balancer bolt- I should be turning clockwise? Just want to confirm...
MidnightAuto is offline
post #2 of 6 (permalink) Old 05-02-2019, 01:14 PM
Quoted: 55 Post(s)
There is no law that says you can't turn it counterclockwise.
But, when the engine is running, it turns clockwise, looking at it from the front.
On a Pontiac V8, the dist shaft/rotor turns counterclockwise.
bigD is online now
post #3 of 6 (permalink) Old 05-02-2019, 04:49 PM Thread Starter
Got it. Thanks big d.
post #4 of 6 (permalink) Old 05-02-2019, 05:18 PM
Quoted: 361 Post(s)
If it turns sideways, then your crank just broke at the snout and that weightlifting program you have been on is working for you.
post #5 of 6 (permalink) Old 05-02-2019, 06:59 PM Thread Starter
Have a feeling my knuckles are going down via fan blades
post #6 of 6 (permalink) Old 05-02-2019, 07:09 PM
Quoted: 361 Post(s)
Much easier if you pull the spark plugs as you won't get the compression fighting you. If the belts are tight enough, you could spin it using the fan blades. Not a lot of room and make sure you don't put any tools into the radiator.
3 Speed Manual vs 4 Speed Manual jayvee53 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 8 10-11-2018 05:07 PM
67 GTO wont turn when hot gsmed 1964-1974 Tempest, Lemans & GTO General Discussion 7 08-20-2005 08:04 PM
What does it take to turn 12's in 2005's chad1140 Racing and Kill Forum 8 05-27-2005 04:49 PM
Keeps blowing 15 amp fuse ? turn/back-up westell Service, Maintenance and Technical Discussion 4 12-14-2004 01:23 PM
Enthusiasts turn old muscle cars into road warriors 05GTO Service, Maintenance and Technical Discussion 1 11-29-2004 05:13 PM
