May I see some electric rad fan setups? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 02-13-2019, 11:12 AM Thread Starter
1968 Q8's Avatar
Hi everyone,
I'm looking to retrofit my stock '68 to electric fan cooling. Just want to get a sense of how any of you have yours setup. Key questions are: What size fan & cfm? Single fan or dual? How easy or difficult is it to mount it within the existing shroud (to appear stock)? I should add that the car has a/c, works when charged, and has a M/T, so no trans cooling.
Thanks, look forward to the upgrade!
- Dan
1968 Q8 is offline
post #2 of 2 (permalink) Old 02-14-2019, 07:14 AM
GTO44's Avatar
Quoted: 38 Post(s)
I convert a lot of older cars to electric fan setups. I try to get as close to 4,000cfm as possible. Especially on an AC car. I prefer duals. Duals with a full rad shroud are best. You'll need some type of controller. Some will come with their own controller where you can twist the knob to set the desired turn-on temp with built in relays so you just run power, ground and acc power. The nicer ones will have a provision for A/C override where you can run your 12volt A/C activation to the controller and it will kick the fan on no matter the temp when you switch the AC on. If you get a fan setup that does not come with a controller you can get a cheapy after market fan controller that comes with a temp probe, relay, circuit breaker, and dial knob for temp setting.
Just make sure your electrical system has enough amperage to run. The bigger fans can draw 25-50 amps total. Always use at least a 10awg wire to run power to the relay and fan (each fan on a separate 10awg if duals). And I never run them direct to key on power as it will tax the system during startup. I prefer Flex-a-lite. Derale is also great. Also, it doesn't necessarily have to be made specifically for your car. Just measure you radiator and look for fans that fit that dimension.
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
stereo setups? virginiavenom 1964-1974 Tempest, Lemans & GTO General Discussion 16 10-27-2011 06:22 PM
need help with wiring up an electric fan xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 09-01-2010 02:52 PM
Non AC rad cradle support vs AC rad support olde-goat 1964-1974 Tempest, Lemans & GTO General Discussion 4 05-13-2010 07:17 AM
GTO Electric Fan Wires ( pinout ) spestis 2004-2006 GTO General Discussion 2 08-27-2009 08:43 PM
69 gto electric fan question 1969gtojohn 1964-1974 Tempest, Lemans & GTO General Discussion 1 05-01-2008 02:51 PM
