Motor too much for a 10 bolt? - Pontiac GTO Forum
post #1 of 2 (permalink) Old 08-09-2013, 01:54 PM Thread Starter
GoatCountry's Avatar
I just purchased a 70 gto that has a rebuilt 455 bored 30 over 462, He put on the engine a 850 holley double pumper, a torker ii cam and intake with ARP rod bolts and forged pistons.
This is my first car and so just learning about everything.
My question is everywhere I read even with the stock 455 it is recommended a 12 bolt rear. I dont know what this motor dyno'd but got a good price on the car and all the sheet metal was done which helps me as I am not the best welder.
Could I upgrade to a 12 bolt in the future if I am not doing burnouts or dropping it etc. Also is this this just going to waste fuel? Is a 850 double pumper truely needed?
TWE
GoatCountry is offline
post #2 of 2 (permalink) Old 08-09-2013, 02:14 PM
Quoted: 117 Post(s)
If you drive reasonably, it'll be ok. If you hammer it and get wheel hop, it won't last forever. If you like the gear ratio, run it. No need to replace it if it's working fine. Holley carbs work well, but waste fuel over the stock Quadrajet. Also, a stock intake is superior to the Torker for both power and drivability. Your choice.
1964 12 bolt to 10 bolt remy30006 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 08-06-2013 10:53 PM
Transmission bolt up to my motor Jaje14 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 11-08-2012 06:01 AM
Is the 10 Bolt 8.2 BOP Carrier the same as Chevy 10 Bolt? mighty454 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 6 04-21-2010 03:30 PM
10 Bolt Versus 12 Bolt Rear Axle take5 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 09-28-2009 03:45 PM
Motor Oil For Newly Rebuilt 400 Motor. pontiacphil 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 01-13-2006 06:40 PM
