Need some help..77' 400 in a 68 GTO..Possible? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 11-28-2017, 11:29 PM Thread Starter
I new to the forum and have not been able to find online if its possible.
Please bare with me for I am new to the GTO world.
I have a 1968 GTO Convertible 4-Speed with a 400.
The short block was wasted so I ended up getting a 1977 block off of a local guy. Sent it out for a complete rebuild, got it back and went to put the motor mounts on and wouldn't you know a 68' 400 motor mount wont fit because its to small.
I found a website that stated "1977 to 1979 did not have the rear motor mount holes at all. Making it very difficult to install in to a GTO/Tempest."
So with that being said.... am I screwed...?
Or do they make a motor mount (or adapter) that will put a 77' 400 into my 68" GTO in the factory position.
Thanks in advance!
perrystroke is offline
post #2 of 4 (permalink) Old 11-29-2017, 11:04 AM
Quoted: 55 Post(s)
"...do they make a motor mount (or adapter) that will put a 77' 400 into my 68" GTO in the factory position..."
Yes. But some say it takes some modification/fabrication, in order to get it all to work.
https://butlerperformance.com/i-2445...tegory:1393557
Paul Spotts sells some cheaper adapters, which do not come with bolts, and do not have nuts welded on 'em.
http://www.spottsperformance.com/mounting
bigD is offline
post #3 of 4 (permalink) Old 11-30-2017, 02:44 PM Thread Starter
I have looked into the Buttler ones so I think I will try that. Has anyone else been in this situation and what was your outcome ?
post #4 of 4 (permalink) Old 12-18-2017, 08:18 PM
Quoted: 31 Post(s)
I don't think you will have any issue getting that engine in. If you don't get the answer you need try the PY site. They have a street pontiac and a 68:69 gto tech section. Doug
dd68gto is offline
new 400 pan on old 400 block Cudaboy_71 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 12 08-09-2017 08:22 PM
A couple questions about swapping my 1967 326/2 speed for 1970 400/400 Crzybone 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 03-25-2012 08:27 AM
