Need TH400 kick down ideas - Pontiac GTO Forum
post #1 of 2 (permalink) Old 12-02-2017, 03:14 PM Thread Starter
I'm working on a 65 GTO with a 389 and TH400 transplanted from a similar year big Pontiac. It has an Edelbrock intake and 1406 4 barrel.
The kick down solenoid is in place on the trany but no switch is present to activate it. The stock set up is long gone.
What are some options that you have found successful to enable the kick down?
I know of the Lokar device...
... and the nitro switch that some are using...
Recomendations? Other/better choices?
Thanks!
Dick Steinkamp
Bellingham, WA
Dick Steinkamp is offline
post #2 of 2 (permalink) Old 12-02-2017, 04:17 PM
Neither, the best set-up is to replicate what was done beginning with '67 GTO's with the stamped steel bracket & kickdown switch at the gaspedal. Little later today, can ck original early Pontiac Master Parts books & dbl ck that the gas pedal Rod is the same between a '65 & a '67.
Kick down solenoid RRconductor76 1964-1974 Tempest, Lemans & GTO General Discussion 2 02-09-2017 10:19 AM
Kick down nessasery CPL 1964-1974 Tempest, Lemans & GTO General Discussion 2 06-18-2016 06:02 PM
kick down switch CPL 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 02-16-2016 06:52 PM
Kick Down Switch marks64 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 07-19-2009 02:14 PM
I got a kick outta this! Good 2 go The Lounge 3 11-28-2005 09:09 AM
