Need your opinion on disc brake vacuum - Pontiac GTO Forum
 4Likes
  • 1 Post By geeteeohguy
  • 1 Post By PontiacJim
  • 1 Post By 05GTO
post #1 of 7 (permalink) Old 05-11-2019, 04:35 PM Thread Starter
RMTZ67's Avatar
Quoted: 65 Post(s)
Not sure where to connect my vacuum from my booster. Can I just T it off at the rear of the carb? Not sure if you can see my current set up but they both currently go to pcv valves.
Ill get a pic in a bit. Not letting me attatch.
RMTZ67 is online now
post #2 of 7 (permalink) Old 05-11-2019, 04:52 PM Thread Starter
RMTZ67's Avatar
Quoted: 65 Post(s)
Heres a pic.
post #3 of 7 (permalink) Old 05-11-2019, 05:11 PM
Quoted: 102 Post(s)
The PCV on a '67 gets its vacuum from two fittings at the front of the manifold, by the carb, that go into a special nylon Tee. The brake booster connects to the carb where your current PCV line is.
ID:	118829   Click image for larger version
deanhickey likes this.
post #4 of 7 (permalink) Old 05-11-2019, 08:49 PM Thread Starter
RMTZ67's Avatar
Quoted: 65 Post(s)
Thanks, I'll search for that tee. Can I hook both pcv valves to that tee? By the way. I was going to order a aftermarket gauge set with a tach and oil pressure gauge. where would I connect the tach wire? Would that be the + on my points distributor? And I am guessing I need different oil sending unit than one for the idiot lights?
post #5 of 7 (permalink) Old 05-11-2019, 10:29 PM
Quoted: 367 Post(s)
Why 2 PCV valves?
Get a manual oil pressure gauge and keep the Idiot light. You can either get a "T" and use one end for the factory electric sender and the other for the mechanical gauge. Other option, and what I do, is to use the small oil hole next to the distributor. It will have a plug in it. Remove the plug and tap the mechanical gauge/line into that oil pressure hole and you will not have to mess with a "T" fitting and keep the Idiot light as is.
Tach will have directions.
RMTZ67 likes this.
post #6 of 7 (permalink) Old 05-12-2019, 12:58 PM
Quoted: 102 Post(s)
He's confused. And needs to look at my picture again. My car is running two PCV valve HOSES....connected to the Tee. And a single PCV valve, plugged into the rear of the Valley Pan. Two hoses are because it is a dual plane intake design and it optimizes vacuum to the PCV under ALL engine running conditions. Very sophisticated for the time.
WideTrack likes this.
post #7 of 7 (permalink) Old 05-12-2019, 02:07 PM
RMTZ67, I would use the hose going to the valve cover PCV for the brake booster and replace that PCV with a vented oil filler cap or plug. Also, the correct PCV connection is illustrated in geeteeohguy's picture.
PontiacJim likes this.
05GTO is online now
HELP, Need your opinion....lemans or gto ? 55gasser 1964-1974 Tempest, Lemans & GTO General Discussion 16 12-05-2011 09:40 PM
Need your opinion 6speedlover 2004-2006 GTO General Discussion 11 08-23-2011 08:15 PM
Need Your Opinion PitoPocket 2004-2006 GTO General Discussion 13 06-19-2009 04:50 PM
Car is burning/leaking oil, ls1 guys need your OPINION! deuce189 Service, Maintenance and Technical Discussion 11 07-26-2007 10:56 AM
So I need your opinion... Holden1984 2004-2006 GTO General Discussion 5 04-16-2007 09:02 PM
