New 461 Stroker Engine - Suspension Upgrade? - Pontiac GTO Forum
post #1 of 8 (permalink) Old 11-05-2012, 08:48 PM Thread Starter
jtwoods4's Avatar
I am about to install a newly built 461 stroker into my 69 GTO. I have already upgraded the rear end to eaton hardended gears (3.42), moser axles, and wilwood disc brakes.
Before I install the engine I want to make sure the suspension can handle the tremendous amount of torque / hp the new engine will produce.
I have been researching 69 GTO suspension upgrades and I am totally overwhelmed by my choices. Do I even need to upgrade the suspension? My stock suspension components are in outstanding condition. If an upgrade is reccomended what components should I focus on?
-JW
jtwoods4 is offline
post #2 of 8 (permalink) Old 11-06-2012, 04:45 PM Thread Starter
jtwoods4's Avatar
Anyone had experience with this?
Sent from my LG-P999 using AutoGuide.Com Free App
jtwoods4 is offline
post #3 of 8 (permalink) Old 11-07-2012, 07:24 AM
allpawl66's Avatar
Rear upper t& lower control arms & connectors . Forged yoke for driveshaft & rear . New driveshaft in moly , poly trans mount & tie the left side of engine down .
allpawl66 is offline
post #4 of 8 (permalink) Old 11-07-2012, 08:15 AM Thread Starter
jtwoods4's Avatar
Okay I have selected the upper lower control arms and connectors from umi performance. Not sure what you mean by tie the engine down. Do I need to purchase different motor mounts or some sort of engine tie down?
jtwoods4 is offline
post #5 of 8 (permalink) Old 11-08-2012, 11:27 PM
He's talking about some sort of semi-solid connection between the left side of the engine and the frame to help keep the torque/twist from shredding the motor mounts. Some folks use chain, some use beefy turnbuckles... I'm sure there are other solutions as well.
post #6 of 8 (permalink) Old 11-09-2012, 08:23 AM Thread Starter
jtwoods4's Avatar
Maybe I could get away with some more Heavy duty motor mounts. Bear what type of motor mount did you use with your engine I know we have about the same builds.
jtwoods4 is offline
post #7 of 8 (permalink) Old 11-09-2012, 08:36 AM
allpawl66's Avatar
Send me your email for pics. of what i did : 461 kauffman headed tri-power roller cam , 4 speed .
post #8 of 8 (permalink) Old 11-09-2012, 04:12 PM
I'm just running good factory style mounts on mine at the present time, but I've got a feeling that they are going to need some "backup" soon
I was considering a length of steel cable secured to the driver's side head and looped around the frame rail.
Suspension Upgrade! Falco21 Drive train, suspension, alignment and brakes. 30 04-25-2011 05:03 PM
Suspension upgrade knaletko Drive train, suspension, alignment and brakes. 11 05-03-2010 02:12 PM
brake/suspension upgrade question busaben 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 03-28-2009 12:30 PM
Suspension upgrade question PEARL JAM 2004-2006 GTO General Discussion 1 03-24-2007 04:59 PM
Noob Suspension upgrade questions coolhandgoat Drive train, suspension, alignment and brakes. 1 02-24-2007 12:49 PM
