Oil filter for 400 - Pontiac GTO Forum
 2Likes
  • 1 Post By bigD
  • 1 Post By geeteeohguy
post #1 of 6 (permalink) Old 06-22-2019, 03:56 PM Thread Starter
Oil filter for 400
Is it important which oil filter is used when doing an oil change? The old STP S25 filter that was on the engine is physically much larger than the Purolator PBL25288 I picked up at my local Advance Auto parts store after checking to see if the fitment for the engine was correct. If it's no big deal, I'll just go ahead with the one I have....or...if bigger is better, I'll go that route. Thanks as always.
John
jayvee53 is offline
post #2 of 6 (permalink) Old 06-22-2019, 04:50 PM
Quoted: 55 Post(s)
A common filter that many use is the NAPA 1258 & Wix 51258. It's the larger size. There are lots of different brands in this size. Many recommend NOT using a Fram brand, or any other brands made by Fram.
https://www.oilfilter-crossreference...vert/NAPA/1258
Unless you need more oil filter to exhaust clearance, there is no reason to use a smaller filter. But, if you do need more clearance, there are several choices. They're about 3" in diameter, and from about 3 1/2" to over 5" long. These also fit some of the LS engines. You can Google the different part numbers & usually find some different sources & the exact specs for most any filter.
The Purolator you mentioned is one of the small diameter filters. I have a Wix 51522 on my drag car, for header clearance.
https://www.oilfilter-crossreference...rolator/L25288
"...if bigger is better, I'll go that route..."
Your filter will work just fine. But, the larger diameter filters have more filter material inside. So, in this case, I suppose you could say that bigger IS better, but only very slightly.
1968gto421 likes this.
bigD is online now
post #3 of 6 (permalink) Old 06-22-2019, 08:58 PM Thread Starter
Thanks BigD, makes perfect sense. Seems maybe a guy (or gal) can go too far being concerned over things that were probably never even considered back when these cars were new!
JV
jayvee53 is offline
post #4 of 6 (permalink) Old 06-23-2019, 06:37 AM
Quoted: 126 Post(s)
Anyone using an oil filter relocation setup ? I'd prefer to go that route with my headers, so I can run a large filter.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #5 of 6 (permalink) Old 06-23-2019, 09:36 AM
Quoted: 362 Post(s)
I am going to answer this, but will do so in a new post so it can become a separate discussion.
PontiacJim is online now
post #6 of 6 (permalink) Old 06-29-2019, 06:04 PM
Quoted: 99 Post(s)
Wix 51258 in both my GTO's and nothing else.
