Opening front end up behind grill - Pontiac GTO Forum
 3Likes
post #1 of 19 (permalink) Old 02-02-2018, 04:39 PM Thread Starter
Quoted: 153 Post(s)
Do folks open up an opening behind the grills to let cold air into the engine bay ? While the engine is far from sealed, there clearly is not a great path of cold air to the carbs....Since I am restoring the car and everything is apart, I have been wondering if folks generally make small modifications like this (as is done with so many other cars). If so, do folks have any pictures ?
Also while I have read about the dealer installed factory scoop (ram air), whereby the hood was cut, it appears the bigger challenge is the fake grill. How did the dealer open up the fake grill in the top center of the hood (sorry don't know what to call it)? Thanks
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #2 of 19 (permalink) Old 02-02-2018, 05:55 PM
I have seen some modify their closed scoops using a dremel tool to cut the center area away. As far as an opening behind the grilles, the radiator of my '70 is just behind the grilles, plenty of air running through.
post #3 of 19 (permalink) Old 02-03-2018, 07:53 PM Thread Starter
Quoted: 153 Post(s)
Yes but that air is quite a bit hotter than the ambient air (maybe)....My thought was to open a hole up on both side to direct cold air right into the engine bay.
Name:	front left grill.jpg
ID:	103041   Click image for larger version
Name:	front right grill.jpg
Current setup:
4 speed Muncie
post #4 of 19 (permalink) Old 02-03-2018, 09:38 PM
Quoted: 390 Post(s)
"How did the dealer open up the fake grill in the top center of the hood (sorry don't know what to call it)?"
I believe the technical term is "hood insert." The cold air or Ram Air inserts were cast as open, just like the non-RA inserts were cast as closed. So two different factory offerings with regards to the hood inserts.
What is your reasoning & goal in directing outside air into the engine bay? Quite a few offerings on Ebay that might give you some ideas. https://www.ebay.ca/sch/i.html?_saca...per+air+intake
post #5 of 19 (permalink) Old 02-04-2018, 07:22 AM Thread Starter
Quoted: 153 Post(s)
Jim - Different hood inserts makes sense as it looked too hard to cut cleanly! My thought was that I could make an opening to the right and left of the radiator and cold air would be directed into the engine bay, hopefully reduce IAT a bit, and reduce the chance of pre detonation / increase HP. While cold air intakes are great, I would have to literally run hoses or tubing up to the carbs and have the carbs isolated from the engine bay air (which I won't do), so I guess it is pointless or would yield little benefit.
Back to wrenching on the electrical system and POR15 work. I am installing the MAD Electrical Start Em' Up kit and probably the light and accessory relays as well and almost done with the POR15 on the floors.
Current setup:
4 speed Muncie
post #6 of 19 (permalink) Old 02-04-2018, 11:28 AM
Quoted: 390 Post(s)
OK, got it. The "Ram Air" systems used by many makers in various forms were in my opinion a little more than the visual looks and bragging rights. It did help to some extent to bring cooler outside air into the engine, not the engine bay, and this was usually at higher speeds.
As long as the hood is in place, it will trap hot engine temps. Mopars seem to run hot under the hood in my opinion and on my 1973 Fury the factory installed seals (flat 1/4" flexible panels) strategically behind the grille to seal off some of the surrounding open areas and channel/force air flow through the radiator area. I think their nose design with its inner fender panels creates more of a box enclosure that traps more heat than lets say a GM product with its inner fender well design and a bunch more open areas for hot temps to escape.
To keep engine temps down, just run a good cooling system using an aluminum radiator, fan shroud, good fan, and a 160 degree thermostat. Correct carb settings (not too lean) and proper ignition timing are also part of a cool running engine.
Of course there is the "old school" remove the hood completely to show off your engine and chromed accessories or what some racers do, lift the rear of the hood with spacers high enough to create airflow out the back at the windshield.
geeteeohguy, 70Koza and cij911 like this.
post #7 of 19 (permalink) Old 02-04-2018, 02:36 PM Thread Starter
Quoted: 153 Post(s)
Jim - Interesting I still can't seem to find anyone that sells the open inserts...I would have thought this was a cold air kit (ram air pan + inserts)....Oh well...
Current setup:
4 speed Muncie
post #8 of 19 (permalink) Old 02-04-2018, 08:21 PM
Quoted: 390 Post(s)
No one sells an open insert as it is easy enough to modify any of the aftermarket closed hood inserts. Fairly simple job with the right tools. If you can't do it yourself, take it to a machine shop and let them do it.
You will also have to cut your under hood bracing as well as the bracing behind the insert.
Name:	01  1965-67 Ram Air hood mods.JPG
ID:	103065   Click image for larger version
Name:	02  1965-67 Ram Air hood mods.JPG
post #9 of 19 (permalink) Old 02-05-2018, 08:43 AM Thread Starter
Quoted: 153 Post(s)
Ah so buy an aftermarket insert and cut that....smart....thanks Jim (again)....
I'd like to buy you a beer, but have a feeling you are no where close....How about mail you some local micro brews ?
Current setup:
4 speed Muncie
post #10 of 19 (permalink) Old 02-05-2018, 12:22 PM
1968gto421's Avatar
Quoted: 72 Post(s)
Ames performance sells an open scoop insert for your '65. Here is the lnk:
https://secure.amesperf.com/qilan/De...A&web_access=Y
Ames also offers the complete inderhood things with the pan and airfilter mods to do a factory ram air setup
http://www.amesperf.com/
Hope all this helps.
1968gto421 is offline
Recessed front grill Cole S Exterior Discussions 5 05-31-2013 08:22 AM
assembling the front end busaben 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 02-17-2013 09:22 AM
G8 front end LS6wantabe Exterior Discussions 33 03-26-2010 05:29 PM
Billet grill with SAP front bumper Speedlyte Exterior Discussions 11 03-28-2007 11:19 AM
Front end work GoToIt 1964-1974 Tempest, Lemans & GTO General Discussion 1 11-01-2004 01:22 PM
