Parts for #13 heads restoration - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-27-2014, 03:10 AM Thread Starter
SPCMarty's Avatar
I have a pair of #13 heads that are being restored. I was wondering if anyone can recommend a proper set of valves and seals for these heads.
I have a set of 6x8 heads and I was curious if I could use its rocker studs, valve spring cups and retainers. Are the springs interchange, or should I just get new ones?
1971 LeMans 350ci 2Barrel Carb
B. Co 1-22 4ID OIF 2008-09
SPCMarty is offline
post #2 of 3 (permalink) Old 01-27-2014, 05:39 AM
I would replace the 40 year old valve springs. Are you replacing the cam? Most cam manufacturers will recommend a spring to match their camshaft. You can usually reuse the retainers unless the valves you use have a different degree valve lock. I would also splurge and get new studs, not much more $$.
post #3 of 3 (permalink) Old 01-27-2014, 10:47 AM Thread Starter
SPCMarty's Avatar
The engine is a fresh rebuild less than 300mi. The deal is I'm not happy with the #142 heads it has now.
What springs would be recommended for stock? I can check with lunati, but the cam is running with stock springed #142s so I figure stock on the 13s will be ok.
I'll get new studs, you're right they aren't much.
SPCMarty is offline
A new restoration project for a '68 GTO convertible, what is the best parts source? GasTiresOil 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 4 11-08-2009 10:49 AM
Parts/restoration catalog sknight751 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 9 03-09-2009 09:35 PM
small parts restoration and inspection stamps Too Many Projects 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 6 02-19-2009 11:07 AM
Early years restoration parts... Crawlin 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 07-02-2008 04:24 PM
