PHS docs: engine unit number 69 judge - Pontiac GTO Forum
post #1 of 12 (permalink) Old 02-05-2013, 10:10 PM Thread Starter
Can the engine unit number ( #'s above the engine code) be matched to PHS documents? If so, where is number located on the PHS? Thanks
stevieray70 is offline
post #2 of 12 (permalink) Old 02-06-2013, 09:30 AM
Quoted: 118 Post(s)
I'm not sure about '69's, but I know earlier cars don't have the EUN on the PHS. The only place to find that is on the protect-o-plate, which should be in your glovebox. If you don't have the POP, you're not alone. They are not common at all, got thrown out, etc. I've had a bunch of these cars, and only one of them came with a protect-o-plate in the glovebox....the '65 I still have.
post #3 of 12 (permalink) Old 02-06-2013, 01:55 PM
The engine unit number's on the Protect-O-Plate? Cool! I didn't know that. I'll have to get mine out and check.
post #4 of 12 (permalink) Old 02-06-2013, 01:59 PM
xconcepts's Avatar
I just found mine for my 66 buried in the glovebox.
xconcepts is offline
post #5 of 12 (permalink) Old 02-06-2013, 02:26 PM
Quoted: 118 Post(s)
Check out the inside of the back cover, Bear. It'll be backwards....you'll have the two letter block code followed by the EUN. Congrats on having the POP, guys!!!
post #6 of 12 (permalink) Old 02-06-2013, 03:52 PM
SANDU002's Avatar
I looked at my '69 PHS and it is not there. It is listed on the PHS for my '67.
67 Post Coupe,
69 RA III Judge
06 BOM, M6, 18's
SANDU002 is offline
post #7 of 12 (permalink) Old 02-06-2013, 03:52 PM
68greengoat's Avatar
Yes. It's on the Billing History form, at least on my '68 doc. Says Engine Unit Number with the number above it......On mine, it's between the Ign key # and the color code.
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #8 of 12 (permalink) Old 02-06-2013, 04:10 PM Thread Starter
Thanks. I called PHS and he said 68 was the last year it was listed on the billing sheet.
post #9 of 12 (permalink) Old 02-06-2013, 05:20 PM
Quoted: 118 Post(s)
Ok....now I'll have to check the PHS on my '65 and see if the EUN is on there! Thanks!
post #10 of 12 (permalink) Old 02-07-2013, 12:34 PM
I never see anyone mention this, but at least for 67, the billing history card supplied by PHS also lists the transmission unit number (TUN?) for automatics in addition to the engine unit number (EUN). And indeed the TUN number on my PHS billing history card matches the number on the little aluminum tag on my PX auto trans. Not sure the manual trans cars had this as well?
Does the POP list the trans unit number? (I don't have my POP, so I don't know)
Squidtone is offline
1970 gto Judge needs 3 prong temp sending unit qpb 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 06-13-2013 02:29 PM
Where is the engine number located ona 1970 GTO / 400 cu? nhp1127 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 10-19-2010 03:56 PM
Removing my A/C unit from '69 Judge aseylys 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 03-30-2010 12:56 PM
Engine code and number Question jay67fast 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 13 08-03-2007 11:34 AM
67 Engine Number Question BarSundown 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 06-12-2006 12:28 AM
