Pontiac Engine Decode help needed. - Pontiac GTO Forum
post #1 of 6 (permalink) Old 02-18-2014, 11:04 PM Thread Starter
Hi All trying to find out year and size. Back by distributer on top of block is C 102. Head manifold has 7h1 and 350 stamped on block.
FireFox3434 is offline
post #2 of 6 (permalink) Old 02-19-2014, 10:21 AM
Norms68's Avatar
Looks like 10 March 1972 (C=March 10=day 2=year) casting 350 with the 1972 heads, 175HP 1.96/1.66 valve size with originally a 7.6 compression ratio.
Found here: Cylinder Heads
-Norm
Norms68 is offline
post #3 of 6 (permalink) Old 02-19-2014, 02:51 PM
Icefan71's Avatar
-Norm
Yep, thats what I have in my 72 Lemans. And the actual valve size is an odd combination, 1.96/1.77. I found out on another Pontiac site from a guy who builds engines. He's seen a few 7H1's and they all have that odd valve combo.
Icefan71 is offline
post #4 of 6 (permalink) Old 02-19-2014, 10:18 PM Thread Starter
Thanks for the help all. I Have a 68 GTO that has that engine in it. With a saginaw 4 speed. Would that engine be a good engine to rebuild? It needs alot of work. If not what is it worth?Bringing the car back from the dead slowely lol.
Tom
post #5 of 6 (permalink) Old 02-19-2014, 10:19 PM Thread Starter
I did the vin on car and it is a true GTO.
post #6 of 6 (permalink) Old 02-20-2014, 07:29 AM
"Good to rebuild"? Well, that depends quite a bit on you and what you want to do with the car. If you care about value, investment or resale, then no -- having a 350 in a 68 GTO hurts it a lot. Performance? again not so good. However, if you want a relatively economical driver, it's not a bad way to go.
Decoding GM Engine Help Needed FireFox3434 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 01-06-2014 02:59 PM
Opinions needed - what engine should I use? TK69tempest 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 34 04-05-2011 08:46 PM
326 Engine Needed Tommy Mac 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 01-08-2011 12:01 PM
'67 GTO engine codes - more detail needed Goat67 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 01-18-2010 02:07 PM
