Pontiac GTO 1967 Camshaft - Pontiac GTO Forum
post #1 of 4 (permalink) Old 01-20-2018, 09:50 PM Thread Starter
Hello
I'm going to build a GTO 67 engine from the start it's a YS 400 I've got 670 heads I'd thought a stoker set 462 cui but what camshaft and lifters should I choose I've just headed the original rock star 4 barrel carburetor and intake
Best Regards
Thomas
Thomas Sørensen is offline
post #2 of 4 (permalink) Old 01-21-2018, 08:34 AM
Quoted: 367 Post(s)
Originally Posted by Thomas Sørensen View Post
Hello
Best Regards
Thomas
In the upper right of this page you will find a red SEARCH button. If you type "camshaft" in the box and click on the SEARCH button it will pull up a lot of info. You can read through the many threads already covering camshaft selection and engine builds to get an idea of cam choices.
post #3 of 4 (permalink) Old 01-21-2018, 09:22 AM
Quoted: 59 Post(s)
Opinions differ, especially on cams. So, these are my own personal opinions. I have no quarrel with those who have different opinions.
(1) Compression: Some say that the 670 heads tend to increase the chances of detonation. So, when you order your stroker assembly, it might be a good idea to order pistons that will reduce the CR down to no more than 9:1.
(2) Cam: The smallest cam I'd even consider is the Summit 2801. It will have a dead smooth idle, plenty of vacuum, and lots of low rpm torque. But, the power will begin to fall off at somewhere around 5000 rpm or less. If you never plan to pull past 5000 rpm, then the 2801 might be OK for you. But, most Pontiac guys consider the 2801 too small for a 455+ Pontiac engine. A similar, but low lift version of this cam is the Pontiac 068 cam, which was used in the 455HO engines.
The Summit 2802 is considered, by many, a decent 455+ cam. It is probably the cheapest decent 455+ cam available. It'll still have a decent idle & vac, and will make good power to 5000 rpm.
https://www.summitracing.com/parts/s...RoCJdgQAvD_BwE
Just above the 2802 is the Crane 283951.
https://www.summitracing.com/parts/c...IaAusEEALw_wcB
Just above that is the Crower 60243.
https://www.summitracing.com/parts/c...gaAjsAEALw_wcB
Next up might be something like the Howard's 410051-14.
https://www.summitracing.com/parts/h...w/make/pontiac
Then, the 041 clone, such as the Melling SPC-8, Comp Cams 51-116-3, & Crower 60919, is still considered a good 455+ street cam. I prefer one of these, used with Rhoads lifters. With the Rhoads lifters, this cam has a decent idle, vac, low end torque, and will pull past 5000 rpm easily.
https://www.summitracing.com/parts/c...saAkSpEALw_wcB
https://www.summitracing.com/parts/rhl-9518l/overview/
Some, including at least one well known Pontiac engine builder, like the Lunati Voodoo cams. So, a 268 Voodoo might be a good street cam.
http://www.lunatipower.com/Product.aspx?id=1776&gid=287
There are obviously bigger cams, and roller cams, available for Pontiac engines. But, if you'll be operating below 5000 rpm, MOST of the time, why buy a cam that will make more power above 5000 rpm, but have a rougher idle, less vac, and less low rpm torque ? In other words, it's better to buy a cam that matches the rpm range you'll be operating in, most of the time. IMO
bigD is online now
post #4 of 4 (permalink) Old 01-30-2018, 12:36 AM Thread Starter
Hey guys
thank you
I think I'm trying to find some original setup
but which pistons and cam / lifters
should I use
I would like a little more hp
I have been rebuilt with head 670
has the original input and 4 bbl
Block 67 YS code 400cui
1967 Pontiac GTO rear end 67GTOCoop 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 8 01-15-2015 10:06 PM
What is this 1967 Pontiac GTO Worth? bobfost2 1964-1974 Tempest, Lemans & GTO General Discussion 8 07-13-2010 04:04 PM
1967 Pontiac GTO Rebuild wizern23 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 6 01-23-2008 03:30 PM
