Postive battery cable length? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 04-26-2019, 06:53 PM Thread Starter
Quoted: 9 Post(s)
Does anyone know the length needed of positive battery cable that will route along the factory location and down the heat shield tube to the starter? 1965 389 tri power, no a/c and manual steering and brakes. Thanks!
wishihaditback is offline
post #2 of 4 (permalink) Old 04-26-2019, 09:19 PM
GTO44's Avatar
Quoted: 37 Post(s)
4awg wire is only $2-$4 a foot. By 5 or 6 feet and trim to fit. I only use flexible welding cable for main power or to starter.
2006 GTO M6
Motor - Stock with Vararam
Bunch of suspension
Bunch of brakes
Stock tune
365/368 std
12.81 @ 110.6 2.03 60'
GTO44 is online now
post #3 of 4 (permalink) Old 04-28-2019, 05:48 PM
Quoted: 98 Post(s)
Order the correct cable from one of the vendors. By far the best quality, fit, and solution. Crimped-to-fit cables are not as good as the factory produced ones with built-in terminal ends.
post #4 of 4 (permalink) Old 04-29-2019, 09:52 AM Thread Starter
Quoted: 9 Post(s)
Thanks for the input guys. $99 for cables from a vendor...no thanks! Not looking for originality, but fairly proper length, especially for the positive cable in a pre-made style. Just wanted to route it along whatever the factory location was. Looked at several '65s online and there is a hodge podge of routings, if visible. Thanks again.
67 lemans tv cable length suggestion Aldo_45030 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 07-07-2017 02:03 PM
What style battery cable is correct? 70conv 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 07-16-2012 10:11 AM
battery cable tube Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 9 07-07-2011 04:14 PM
Battery Cable Ground injn37 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 07-02-2010 08:54 AM
