Power Steering Pully Removal - Pontiac GTO Forum
post #1 of 6 (permalink) Old 11-24-2013, 04:43 PM Thread Starter
I borrowed a pulley removal tool set before taking a close look at my power steering setup. My pulley does not have a lip to grab a hold of to put pressure on the shaft.
I attached a picture of my pulley. Has anyone removed one like this before?
young99 is offline
post #2 of 6 (permalink) Old 11-25-2013, 08:31 AM
You may find that one you remove the nut it'll slide right off. It's probably keyed to the shaft. If it needs persuading, either tap the shaft with a hammer while supporting the pulley (LIGHTLY! you don't want to booger up the threads on the shaft) or use on old-style wide jaw puller.
post #3 of 6 (permalink) Old 11-25-2013, 12:36 PM
the65gto's Avatar
Quoted: 12 Post(s)
Your pulley looks to have more beef than my 65. I used a wide jaw puller and bent the heck out of my pulley getting it off. I put it back on the old pump and straightened it smooth with an adjustment tool (hammer) before mounting it on the new one. Like Bear said, I just held the pulley horizontal with my left hand, pump about 1" off the work bench, and gently tapped the shaft and it came off.
the65gto is offline
post #4 of 6 (permalink) Old 11-25-2013, 01:27 PM Thread Starter
Thank you guys for the input. I will give this a shot tonight.
young99 is offline
post #5 of 6 (permalink) Old 11-25-2013, 07:11 PM
JVM225's Avatar
It's been a while, but I remember mine coming off pretty easy once the nut was removed.
JVM225 is offline
post #6 of 6 (permalink) Old 11-26-2013, 09:23 AM
Quoted: 118 Post(s)
Give it a shot of PB blaster or WD 40 or penetrating oil, too. It's a keyed shaft.
67 Gto Steering Wheel Removal SPRAYPRODUCTS 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 14 12-14-2014 07:53 AM
need help steering column removal 66gto 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 8 04-27-2014 07:00 PM
65 GTo manual steering to power steering? d.reese 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 08-10-2009 06:51 PM
