Power Steering Pump Holes - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-21-2013, 03:00 PM Thread Starter
I was looking at my power steering pump and noticed a little fluid coming out of the holes toward the bottom of the pump. I attached a picture with arrow of the holes I am curious about. What are these holes for? my mount is attached to the top 2 holes I believe.
Well I think it is only coming out of the bottom left hole.
young99 is offline
post #2 of 3 (permalink) Old 09-21-2013, 03:22 PM
Quoted: 118 Post(s)
Those are drilled and tapped holes for other applications to install a mounting bracket. They don't go thru into the pump reservoir. More likely, you have a leaking shaft seal or a leaking pump body seal. Clean it off with brake cleaner and see where the fluid is coming from. My '67 had a hard to find leak, and it turned out it was the pump body gasket. I got an overhaul kit off of the internet for $11 and overhauled the entire pump. Took longer to R&R the darn thing than it did to overhaul it. Good instructions on 'how to' can be found on line. Good luck.
post #3 of 3 (permalink) Old 09-21-2013, 03:33 PM Thread Starter
Thank you for the quick update. I will pick up one of the kits and go through it. That is a good idea.
young99 is offline
Help with power steering pump on 68 GTO dimitri 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 9 12-02-2010 09:15 PM
71+ power steering pump with 67-70 brackets? hookemdevils22 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 10-29-2010 06:09 PM
Power steering pump id cohio 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 09-18-2010 07:18 PM
power steering pump 2004americanmuscle Service, Maintenance and Technical Discussion 3 10-04-2009 03:09 PM
Power Steering Pump pacautotoys 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 10-21-2005 02:37 PM
