power steering pump question. - Page 2 - Pontiac GTO Forum
post #11 of 16 (permalink) Old 05-25-2019, 12:13 PM Thread Starter
RMTZ67's Avatar
Quoted: 62 Post(s)
Just enjoying breakfast outside before I go into the garage and get hot and cranky. Looked at it last night again and everything lines up except the pp. Jim I see that washer you are talking about. I'll take the pump out and look it all over again and see if anything pops out at me. One more question though. I installed my new front calipers reversed and have put them back correctly "with the bleeder up" now It wont bleed. I am guessing the proportioning valve is closed so that the whole system will not fail. How do I get that centered again? It is a aftermarket disc set.
ID:	119217   Click image for larger version
RMTZ67 is offline
post #12 of 16 (permalink) Old 05-25-2019, 12:34 PM
Quoted: 333 Post(s)
Originally Posted by RMTZ67 View Post
Just enjoying breakfast outside before I go into the garage and get hot and cranky. Look at it last night and everything lines up except the pp. Jimmy I see that washer you ar talking about. I'll take the pump out and look it all over again and see if anything pops out at me. One more question though. I installed my new front calipers reversed and have put them back correctly "with the bleeder up" now It wont bleed. I am guessing the porpotioning valve is closed so that the whole system will not fail. How do I get that centered again? It is a aftermarket disc set.
Check out this YouTube video. It may help and you can start from there. https://www.youtube.com/watch?time_c...&v=qPLaPv8DITE
post #13 of 16 (permalink) Old 05-26-2019, 08:57 PM Thread Starter
RMTZ67's Avatar
Quoted: 62 Post(s)
Well Jim, this video showed me I should probably read the directions first. I removed the bleed plug before bleeding thinking it was a shipping plug along with the rest. Its has been disposed of. Come to find out those are going for $14.00. Anyway I emailed the company asking for the easiest way to center the pin. Mean while I'll Google some more. Maybe I'll find a easier solution which might be buying another one. Thanks
RMTZ67 is offline
post #14 of 16 (permalink) Old 05-29-2019, 06:20 PM
I fought similar problem, turns out I needed the 4 inch water pump not the 4.5. I fought this for days before changing water pump and now everything lines up.
Good luck,
Rednekk
Real69gtojudge! is offline
post #15 of 16 (permalink) Old 05-29-2019, 09:20 PM
Quoted: 333 Post(s)
LOL. You are learning my way. Never read directions, dig right in, pull stuff apart because we are "guys", then scratch your head trying to figure out why things just are not working. And never admit you did not read the instructions, rather, tell everyone that you did not understand them as they were written, they just were not clear enough!
You should be able to get the bleeder valves from most auto parts stores on their Help tree of parts.
post #16 of 16 (permalink) Old 05-31-2019, 05:29 PM
Lemans guy's Avatar
Quoted: 46 Post(s)
Also t
Here is a small bolt nut and a thick washer on the very bottom right side. (As you are in the drivers seat) of all that
Bracetry, ...the washer is a thick black spacer and as I recall it goes in between the two brackets....if you put it back or front it will misalign the pulley as I recall. I had to always put the car on the lift to get to that nut easily,....not sure I can see it in the photos...
It is the lowest and farest adjustment , where the two bracket ends meet.....
That is why I went to serpentine belt!
Lemans guy is online now
power steering pump 2004americanmuscle Service, Maintenance and Technical Discussion 3 10-04-2009 03:09 PM
Power Steering Pump pacautotoys 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 10-21-2005 02:37 PM
power steering pump whines Goat666 Service, Maintenance and Technical Discussion 10 12-10-2004 06:02 PM
