pulleys - Pontiac GTO Forum
post #1 of 4 (permalink) Old 05-22-2019, 06:57 PM Thread Starter
ricknkjo's Avatar
pulleys
I am finishing up my rebuild on my 1966 389 and installed the Butler upgrade to a 11 bolt water pump and am also adding A/C. I am using the stock alternator and power steering brackets but the pulleys are not lining up at all. The upgrade kit came with the timing cover, water pump, balancer, and water pump pulley. I purchased a March 3 groove crank pulley and it all seems to be off about 1/2 of the groove. Has anyone else had this issue?
ricknkjo is offline
post #2 of 4 (permalink) Old 05-22-2019, 07:37 PM
BLK69JUDGE's Avatar
Quoted: 42 Post(s)
yes you will have problems...
none of your 66 stuff will work with the 11 bolt water pump
nothin
but a few bolts .... nothin ..............
not even the rear alternator bracket to intake ...
everything changed depth with the 11 bolt cover from a 66..
67-70 on pump n brackets
68-70 crank pulley
69 70 water pump pulley
are needed for correct align ment
BLK69JUDGE is online now
post #3 of 4 (permalink) Old 05-23-2019, 11:09 AM Thread Starter
ricknkjo's Avatar
It looks like the problem is the bottom pulley, so I think I need to have one made to match my needs. I had to add about 1" to the front alternator bracket to make it work with the 11 bolt pump.
ID:	119199   Click image for larger version
ricknkjo is offline
post #4 of 4 (permalink) Old 05-23-2019, 11:38 AM
BLK69JUDGE's Avatar
Quoted: 42 Post(s)
well'
if you can make parts ..that work
you need to market them
are u/d pulleys worthit for 'normal' driving? 7moon12 2004-2006 GTO General Discussion 1 03-15-2008 02:14 AM
Pulleys with sound system wafi 2004-2006 GTO General Discussion 1 01-14-2006 06:34 PM
pulleys keoni1978 1964-1974 Tempest, Lemans & GTO General Discussion 0 01-17-2005 03:11 PM
