Question about motor mount modification - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-07-2018, 07:50 PM Thread Starter
I recently installed a 400 in my 65 4 spd goat. I installed cast iron headers and have an issue with clearance between the drivers side header and the rag joint. The rag joint studs are rubbing the bolt head on the front of the header. I am thinking of cutting a 1/4 inch steel plate to place under the frame half of the motor mounts. I would cut this to match the frame mount and drill to bolt directly under the mount. Will raising the engine 1/4 inch effect the drive line in any way, such as creating a vibration?
big iron is offline
post #2 of 5 (permalink) Old 10-07-2018, 09:03 PM
Quoted: 59 Post(s)
Don't see how only a 1/4" change could cause any problems.
bigD is online now
post #3 of 5 (permalink) Old 10-08-2018, 10:07 AM Thread Starter
Thanks big D. In looking through past threads I read a comment that there can be sag over time that draws the front frame rails together thus lowering the engine which could be the culprit in my case. In any case I am going ahead with installing at least 1/4 " plates to lift the engine.
big iron is offline
post #4 of 5 (permalink) Old 10-08-2018, 12:40 PM
It's possible that it might throw the u-joint angles off and introduce a vibration, but 1/4" near the front of the engine is a pretty small change. If that happens, I recommend installing adjustable upper rear control arms to enable bringing things back into alignment.
For your reference, the image below shows proper alignment if you're not already familiar with it.
post #5 of 5 (permalink) Old 10-09-2018, 09:48 AM Thread Starter
Very helpful information. Thanks BearGFR!
big iron is offline
Motor Mount replacement question cthomas11 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 01-14-2018 04:34 PM
Motor Mount Question nraven68 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 02-07-2014 05:16 PM
motor mount question pr0zac 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 29 03-31-2010 06:15 PM
B&M Shifter - modification needed. LS2FAST Service, Maintenance and Technical Discussion 5 11-08-2005 08:14 PM
engine modification value mc364 Service, Maintenance and Technical Discussion 0 12-24-2004 03:10 PM
