Rebuilding Motor - Page 2 - Pontiac GTO Forum
 6Likes
post #11 of 13 (permalink) Old 04-24-2018, 09:48 PM Thread Starter
Cory Wood's Avatar
Well I got the exhaust all done. Now I can hear i knocking sound coming from the passengers side. I think it is a stuck lifter. So I took it to the builder and he says pull it or his service shop will do it for $1600.00 Ouch and he will dismantle it and find what has went wrong, he says it sounds like a piston to him. But the bad thing I noticed is a leaky Rear Main also. So I am going to have to pull the motor again!!! I have heard to buy a Viton 2 piece seal " Rear Main Seal Kit TIP-RM300 with Permatex Ultra Black RTV Silicone Help don't know what to do. I put a link to a video to show you what it sounded like before I got the exhaust done
ID:	109402   Click image for larger version
Name:	Viton rear main.jpg
Cory Wood is offline
post #12 of 13 (permalink) Old 04-25-2018, 10:18 AM
Cory, get yourself a long piece of wooden dowel, or perhaps a cut off section of a broom handle (works good due to the rounded end). Press one end into your ear, put the other end on various parts of the engine with it running and making the sound. What you're doing is using it like a stethoscope. This will help you localize where the sound is actually coming from, be it near the rockers or down in the block. That'll tell you something about possible causes.
I'm in the process of a rebuild on my engine and this time I used one of the new 1-piece rear main seals from BOP. Your leak might be the seal, or it also could be the oil pan gasket. I shot some video of installing the BOP 1 piece rear seal that I still need to edit together and post. It's a very good solution to one of the "main" problem areas in Pontiacs.
post #13 of 13 (permalink) Old 06-15-2019, 09:04 PM
Quoted: 31 Post(s)
Bear this old post I was just looking at. Wonder what happen beside him getting screwed by his shop. Maybe he push that broom handle in his ear a little to far. Just kidding buts it's funny how some just disappear. Doug
dd68gto is offline
Rebuilding the differential Guinness 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 06-28-2016 08:26 PM
Recommendation for Engine Rebuilding 67PLUMMIST 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 8 04-03-2015 07:15 AM
Rebuilding '65 389 3x2's motor (Suggestions) sbutler 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 12-23-2009 08:36 PM
rebuilding thc301 Engine Discussions 5 06-21-2007 09:37 PM
Need Help Rebuilding! Split1atom 2004-2006 GTO General Discussion 3 12-10-2004 05:22 AM
