Rebuilt engine start up advise - Pontiac GTO Forum
post #1 of 13 (permalink) Old 09-20-2012, 04:47 AM Thread Starter
SPCMarty's Avatar
Well this is my first engine rebuild and after I prime the oil system it'll be ready to start up. Is there anything I ought to be aware of, and any techniques for initial startup once it's running? Should I be at 0 degrees TDC or at 10 degrees BTDC?
It's a 1977 400 bored .030 over with a lunati cam and 142 heads. Compression should be right at 9.3. It had a points distributor for some reason, so I put in a crane xri electronic conversion.
B. Co. 1-22 Infantry 4th Infantry Division OIF 2008-09
1971 LeMans 350ci 2Barrel Carb
B. Co 1-22 4ID OIF 2008-09
SPCMarty is offline
post #2 of 13 (permalink) Old 09-20-2012, 09:29 AM
You should be 6 degrees BTDC with the vacuum advance disconnected, once you reconnect the vacuum the reading should be between 6-12 ATDC.
05GTO is offline
post #3 of 13 (permalink) Old 09-20-2012, 11:41 AM
68GTO4004Spd's Avatar
If you replaced the cam you will want to start it and run at 2000 rpm for about 15 min. to do a cam break-in.
68GTO4004Spd is offline
post #4 of 13 (permalink) Old 09-20-2012, 03:17 PM
the65gto's Avatar
Quoted: 12 Post(s)
My experience has been to pre lube the engine, remove distro and turn the oil pump to build oil pressure, hand turn the engine and repeat. Next when it fires, there will be a lot of smoke and the temperature will climb quite fast as it breaks in, oil spilt around the engine will smoke, exhaust if new will odorize the area. Keep an eye of the oil pressure, fluid leaks and temperature during the cam break in. I kept a timing light connected to monitor the timing, slightly tweaking and at the same time adjusting the carbs, expecially if they are new or rebuilt. Its 15-20 minutes of real excitement.
the65gto is offline
post #5 of 13 (permalink) Old 09-20-2012, 04:49 PM
69Goatee's Avatar
Check around the exhaust and moving parts for any wires, hoses and ect.. touching them. Give everything the wiggle test to see if anything will move onto hot or moving parts. AND check the heat crossover in the intake manifold for wires and vacuum tubes laying across it, it gets hot enough to melt stuff and start small fires....ask me how I know.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
RESTORATION IN 1980...
NIN
69Goatee is offline
post #6 of 13 (permalink) Old 09-20-2012, 05:11 PM Thread Starter
SPCMarty's Avatar
Setting it to 6 degrees BTDC is literally turning the crank to the 6 degree mark correct? Am I took hook up the vacuum advance hose after its reached operating temp? The cam is brand new. My Lemans doesn't have actual oil pressure or temp gauges, would y'all recommend hooking up a set of real gauges.
SPCMarty is offline
post #7 of 13 (permalink) Old 09-20-2012, 06:13 PM
I would hook up oil pressure and temp gauges at least while you break in the new motor.
You can install em temporarily if you don't like how they look or put em in the glovebox or underhood.
Unhooking the vacuum advance is for setting timing only. To start the motor I would leave the dist semi tight/loose so you can turn it by hand and run the motor initially where it "feels" best. After it's running smoothly you can check the timing with a light. As others have said it's that first 15-20 min that is critical.
I hope you have a good exhaust on it and don't piss off your nieghbors .
Good luck and have fun.
post #8 of 13 (permalink) Old 09-21-2012, 12:04 AM Thread Starter
SPCMarty's Avatar
I'm going to need the correct oil pressure and temp sending units first though arent I? How many quarts does the 400 take? I only got 5 in there before dipstick read full
SPCMarty is offline
post #9 of 13 (permalink) Old 09-21-2012, 12:44 AM
FlambeauHO's Avatar
Quoted: 8 Post(s)
Make sure you use the ZDDP additive during cam break-in!
FlambeauHO is offline
post #10 of 13 (permalink) Old 09-21-2012, 01:30 AM Thread Starter
SPCMarty's Avatar
I've got Amsoil 30w break in oil in it right now
SPCMarty is offline
Questions regarding turning over rebuilt engine olde-goat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 08-05-2012 11:31 AM
'70 GTO Engine advise Mike2005Vette 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 1 09-07-2009 05:01 PM
Rebuilt engine, steering funny? gotgoat Engine Discussions 4 12-10-2008 08:14 AM
