Recommended fan - Pontiac GTO Forum
 1Likes
  • 1 Post By bigD
post #1 of 4 (permalink) Old 02-01-2018, 06:58 AM Thread Starter
Quoted: 135 Post(s)
Recommended fan
I have a 1965 GTO and someone just told me that my fan was a flex fan (?), yet to me it looks like a standard steel fan. That said, I currently do not have a clutch and will install shortly.
My question is what is the best fan to use when installing the larger aluminum radiator and shroud sold by AMES (I believe the shroud will work up to 17.5") ?
Should I get this one https://secure.amesperf.com/qilan/De...A&web_access=Y
Attached is a picture of my current fan. Thanks
Chris
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #2 of 4 (permalink) Old 02-01-2018, 10:59 AM
1968gto421's Avatar
Quoted: 70 Post(s)
This fan should work fine with a quality Hayden fan clutch. My concern is Ames states the fan is 18" and you mention the shroud is 17.5". My understanding is that the center of the fan blades should be aligned with the edge of the shroud. If I'm correct, you may have clearance problems.I have found the Ames tech folks to be very knowledgeable about their stuff. I would check with them about the compatibility of the fan and shroud.
I sympathize with your problems as my '68 has a cheap flex fan from previous owners and I need to change it to a clutch fan and un-do stuff that was modified. Best of luck to you.
1968gto421 is offline
post #3 of 4 (permalink) Old 02-01-2018, 02:35 PM
Quoted: 59 Post(s)
If your shroud is indeed only 17.5", a Flex-a Lite #1817 17" 7-blade flex fan might work, if it's positioned in the shroud correctly.
https://www.amazon.com/Flex-lite-181.../dp/B000CNLCMA
If you prefer a clutch fan, Derale makes a 17" 6-blade.
https://www.amazon.com/dp/B0006HNLSA...51dlvjrz_e_p37
The Flex-a-Lite 5717 is listed as 17.25". That might be cutting it too close, if the shroud opening is only 17.5".
https://www.amazon.com/Flex-lite-571.../dp/B000CNJBM8
The engine will rise slightly, on the driver side, unless you have a solid motor mount, or have that side secured with chain, cable, turnbuckles, or some other sort of restraint. With minimal fan-to-shroud clearance, the fan could contact the shroud if the engine rises even a very small distance.
For max cooling, some recommend the 2797 Hayden Severe Duty clutch.
https://www.amazon.com/Hayden-Automo.../dp/B000C3F3D4
1968gto421 likes this.
bigD is online now
post #4 of 4 (permalink) Old 02-01-2018, 04:22 PM Thread Starter
Quoted: 135 Post(s)
BigD - Thanks!! The shroud is designed for fans up to 17.5", so I am guessing the actual opening is quite a bit larger (I will measure). Are the Flex-a-Lite decent ? I have heard some say they are not good ?? Thanks
Current setup:
4 speed Muncie
1970 GTO fan/fan shroud Remove rolm 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 01-21-2017 09:25 PM
Recommended AGM Battery? xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 09-20-2013 11:41 PM
Clearance between Radiator Fan shroud and fan jtwoods4 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 07-22-2012 04:51 PM
Recommended Fuel the65gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 16 11-12-2008 07:06 AM
Recommended Tire csette85 Wheels and tires 15 09-23-2007 11:47 PM
