ring gaps - Pontiac GTO Forum
post #1 of 7 (permalink) Old 06-11-2018, 03:10 PM Thread Starter
ring gaps
My 326 has just been bored 40 over and I bought new pistons. the question I have is the stock ring gap still what I use or will there be a different ring gap.
tspring is offline
post #2 of 7 (permalink) Old 06-11-2018, 03:26 PM
Quoted: 367 Post(s)
You want to gap the rings per your piston manufacturer/supplier. Pistons today are made of a number of different materials - some can use a tighter gap because they expand less while other expand more and need wider gaps. I would not necessarily rely on what "the book" tells you.
You may also want to ask the machine shop who bored out your block.
post #3 of 7 (permalink) Old 06-11-2018, 04:57 PM Thread Starter
this is the info on side of the box my pistons cam in: minimal clearance .0015, skirt size 3.75825 +/- .00025,measuring point 2.61 from top of head. This is all the info that came with the pistons.
tspring is offline
post #4 of 7 (permalink) Old 06-11-2018, 06:44 PM Thread Starter
a question about oil rings
I checked the gaps according to the manual and all gaps are according to specs between .010 and .020. on the oil rings there are 2 types. one ring will have a gap and the other has tabs that slide over each other. Does it matter which one goes on top. All the vids that I looked at on you tube never showed there being 2 different types of oil rings
tspring is offline
post #5 of 7 (permalink) Old 06-11-2018, 07:49 PM
Quoted: 367 Post(s)
OK, the .0015" is the clearance between the piston and cylinder wall reading what I see. Typically the piston manufacturer will have a formula that takes into account the engine/piston use and then provide a "ring gap factor" to multiply your piston diameter size by. Read this article here: Are ring gaps really THAT important?
My generic Pontiac engine book says the ring gap should be between .010" and .020". Your 326 .040" has a bore size of 3.76". Cross referencing this to my 1968 Service manual for the 6 cylinder, its bore is 3.875" - so not too far off. My manual states the top/second ring gap is .015" +/- .010".
The '68 Service Manual says the oil ring gap is larger at .035" +/- .020". My generic Pontiac engine book says the gap should be .015" to .030" - so this falls within the range from the '68 manual for the 6 cyl.
On the oil rings, I don't think it matters which end goes over the other. The oil expander goes between the two flat steel rings (which are both the same) with the flat rings holding it into place. Put the expander ring on first, then 1 flat ring at the lower ring groove locking in the bottom oil expander. Then put the other flat ring at the top of the lower ring groove to lock in the top of the oil expander - think of it like a sandwich.
You want to make sure your rings are orientated correctly as there is an up and down side - some have a dimple, some are by shape. The ring gaps also need to be orientated so that no end gaps line up. The oil scraper will join at the piston pin on the rear side of the piston (piston orientated to face the front of the engine if yours have a specific orientation - an "F" or notch). The the top oil ring will be 1" to the left of the oil scraper joint and the bottom oil ring will be 1" to the right - this staggers all the end gaps so none line up. The top and 2nd ring gap will be orientated opposite/across from the oil ring gaps.
You want to use a ring expander to slide the rings over the piston rather than try and spiral then down over the piston which could damage or break them.
Hope that helps and doesn't confuse you.
post #6 of 7 (permalink) Old 06-11-2018, 08:38 PM Thread Starter
Thanks for the good info. I think my gaps are good. I put all the rings on with no problem. The bottom compression ring had a mark indicating that it goes on the top and the top compression ring was flat with no marks so there was no indication that they had any orientation. I put the oil ring gaps 180 degrees from each other and the compression ring gaps 180 opposite from the oil ring. I have heard 10 different ways to clock the rings but it seems that as long as they are not lined up with each other they will be ok.
tspring is offline
post #7 of 7 (permalink) Old 06-13-2018, 09:42 PM
Quoted: 367 Post(s)
OK, sounds like you have it all under control. I too have heard 10 different ways to clock the rings and then ....the rings move around the piston and change positions anyway. So like you, I just make sure the gaps are staggered or offset and not lined up.
o-ring leaking Mav 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 22 02-18-2018 10:58 PM
ring orientation mjc707 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 03-21-2017 07:27 PM
door gaps foreevergoat 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 2 09-30-2014 08:00 AM
Driver's side fender gaps & Rust proofing. Joe'sToy 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 26 05-05-2012 08:48 PM
intake O ring Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 7 02-09-2011 06:56 PM
