Smaller/narrower oil filter for 400 cubic inch engine - Pontiac GTO Forum
post #1 of 11 (permalink) Old 07-15-2012, 09:18 AM Thread Starter
ppurfield001's Avatar
I have a tough time fitting the standard-sized oil filter into my 1967 GTO with headers. Any idea of a smaller/narrower oil filter that would be much easier to use? Thanks in advance.
ppurfield001 is offline
post #2 of 11 (permalink) Old 07-15-2012, 09:31 AM
It's a common problem. I've heard of folks using filters that are shorter, remote filter systems, etc. Do make sure you have the right filter housing. It's the one that sort of angles the filter back towards the block a little bit. That can make a difference too.
post #3 of 11 (permalink) Old 07-15-2012, 09:36 AM
Paul, you need the 110* filter housing, and a shorty filter.....p-24 (?).... ERIC
Eric Animal is offline
post #4 of 11 (permalink) Old 07-15-2012, 02:18 PM Thread Starter
Saw an oil filter in the Ames Performance catalog that measured three inches in diameter and four and five-eighths in length and was recommended when additional clearance for headers is needed. Car is in the shop. Will check it out tomorrow. Thanks for the suggestions.
post #5 of 11 (permalink) Old 07-15-2012, 02:31 PM
rickm's Avatar
Quoted: 5 Post(s)
ac part # PF61 fram PH3675 original application was a late model trans am. its got good clearance with headers, but now your capacity will be 5- 1/2 qts. instead of 6 . rickm.
rickm is offline
post #6 of 11 (permalink) Old 07-15-2012, 03:23 PM
I have the same problem with the 428 and headers.. I now use the "Wix 51522" filter. The Delco PF61(e) should also fit.. I use them on my Cadillac and they seem to have pretty much the same size.
That's the link to the Wix filter Part Detail
Chris-Austria is offline
post #7 of 11 (permalink) Old 07-15-2012, 10:49 PM
Filter housig
Where can you get a 110* housing?
orelog is offline
post #8 of 11 (permalink) Old 07-16-2012, 08:30 AM Thread Starter
Thanks for all the suggestions.
post #9 of 11 (permalink) Old 07-16-2012, 09:51 PM
Check with Butler performance...they have them, they also have a nice "remote mount" filter kit. ....I have one around somewhere..I'll look for it. Eric
post #10 of 11 (permalink) Old 07-16-2012, 09:54 PM
Also, Kevin Swaney has them at Tin Indian Performance (very nice valve covers also!)
fit smaller water pump pully to stop overheating fiesta62 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 20 12-28-2011 03:22 AM
Cubic Inch math. Gran Turismo 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 09-07-2011 05:51 PM
Narrower rims johni53 Wheels and tires 6 09-04-2010 06:05 AM
454 cubic inch ss78300 1964-1974 Tempest, Lemans & GTO General Discussion 0 11-21-2006 12:52 AM
04/05 cubic in? EEZ GOAT Service, Maintenance and Technical Discussion 6 10-02-2005 09:05 PM
