steering - Pontiac GTO Forum
post #1 of 5 (permalink) Old 02-03-2012, 07:10 PM Thread Starter
steering
I'm a relatively new owner of a 67 GTO. There is a 6 inch "play" in the steering wheel.. Is this normal?
Also, when making a U turn, I hear funny noises under the hood. Is this normal?
Jack
JackMcCord is offline
post #2 of 5 (permalink) Old 02-03-2012, 08:09 PM
crustysack's Avatar
no and no you need to go thru the steering system, if you are the new owner check it or have a qualified mechanic look at it, could need new ps pump, idler or pitman arm, tie rods etc. steering should be tight with no"funny noises" . Steering components wear out and need to be replaced to insure maximum performance( and safety)
crustysack is offline
post #3 of 5 (permalink) Old 02-03-2012, 09:09 PM
Quoted: 118 Post(s)
Ditto. You should have between o and 1 or 2 inches of play max at the steering wheel. Common wear areas on your car : center link, idler arm, tie rod ends. Other likely worn items are A-arm bushings, both upper and lower, and ball joints. Usually the gearbox is ok. Check the rag joint where the column connects to the gearbox...sometimes these rip and give you a lot of play and clunking.
post #4 of 5 (permalink) Old 02-03-2012, 09:12 PM Thread Starter
thanks
Thanks a lot. This forum is great! Now I know there is a solution. The steering box and pump have minor leaks and I'll replace them and see if this fixes the problem. If it doesn't, I'll try to find a mechanic who knows a little more about steering systems.
Thanks a lot for your help.
Jack
post #5 of 5 (permalink) Old 02-03-2012, 10:34 PM
Quoted: 23 Post(s)
I know the center links on the 66' are hard to find and are not the same as other a-frames of the same year, front end rebuild kit is well worth the money for safety and handling.
Instg8ter is offline
steering box olddude 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 14 10-10-2015 07:15 PM
65 GTo manual steering to power steering? d.reese 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 08-10-2009 06:51 PM
Steering Effort tanktronic 2004-2006 GTO General Discussion 5 10-10-2007 06:02 PM
