steering coupler - Pontiac GTO Forum
post #1 of 4 (permalink) Old 02-21-2014, 06:46 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
steering coupler
Got my new steering box and am confused about the coupler. where does the bracket go? took a guess in the 2nd pic. My old leaky one didn't have this part
Also I was going to take off the coupler and match it up to the steering shaft but its really tight (lol) like it's not supposed to be removed......
Don't I need to be able to slide it about to get minimum endplay? or is there supposed to be any?
thanks as always
Tk
ID:	34337   Click image for larger version
ID:	34345   Click image for larger version
Topkat is offline
post #2 of 4 (permalink) Old 02-21-2014, 09:22 PM
TK,
The purpose of that bracket is to pass ground thru the coupler (rag joint) for the horn, part of it should attach to the column and the other part should connect to the steering box shaft .
05GTO is offline
post #3 of 4 (permalink) Old 02-22-2014, 12:23 PM
Quoted: 117 Post(s)
And as for the press-on spline fit, take a tapered cold chisel or slot screw driver (or any wedge shaped piece of metal like a hammer wedge) and insert it in the seam to help spread the joint. WD 40 helps, too.
post #4 of 4 (permalink) Old 02-22-2014, 06:00 PM Thread Starter
Topkat's Avatar
I bolted it onto the car. I tried to center the steering wheel and guesstimate the center of travel of the box but its off
Is I supposed to spread the seam enough to let it turn about the shaft for alignment purposes?
How do I get the box centered so the steering wheel is centered too?
(today)hmmmm... I removed the box and have the "v" pointing down about 1 1/2 turns(of steering wheel) on either side....mayhaps making too much of this?
Guessing to put the pitman arm on, I need to straighten the wheels and?? Is the "seam" gonna give me my final "get the steering wheel straight adjustment??
thanks as always
Tk
Topkat is offline
steering JackMcCord 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 02-03-2012 10:34 PM
diveshaft rubber/coupler smoky Drive train, suspension, alignment and brakes. 5 10-10-2010 11:03 AM
AC on does it lessen power on 05 gto? and question about rubber driveshaft coupler... pctek Service, Maintenance and Technical Discussion 4 08-01-2010 11:36 AM
65 GTo manual steering to power steering? d.reese 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 08-10-2009 06:51 PM
