Strange engine code - Pontiac GTO Forum
post #1 of 7 (permalink) Old 02-01-2019, 11:07 AM Thread Starter
Strange engine code
Hi Guys- need some help. I have a 1968 GTO that was built in Fremont. When I purchased the car, the original motor was included in the deal. 9790071 YS. I have that motor on a stand preparing for rebuild. The car came with a running motor in it. Here’s the catch: it’s a block code 9799914 YD. I have the Pontiac casting # book and can’t find that motor. It’s currently got the #16 heads and 4bbl intake from the original motor on it. Is this block a ghost? I’m pretty sure it’s a 70 casting.
Bill E is offline
post #2 of 7 (permalink) Old 02-01-2019, 12:14 PM
BLK69JUDGE's Avatar
Quoted: 63 Post(s)
going from memory
1970
290 hp
4 bolt block
2 bolt caps
good engines .... 1 year casting
BLK69JUDGE is online now
post #3 of 7 (permalink) Old 02-01-2019, 12:58 PM Thread Starter
I get it that you’re going by memory but I can’t find it anywhere. What makes you sure?
Bill E is offline
post #4 of 7 (permalink) Old 02-01-2019, 01:37 PM
Quoted: 59 Post(s)
Yeah, a '70 YD is a 290hp 2-barrel 400.
Just type in YD, on the engine code line.
Wallace Racing's Pontiac Engine Search
bigD is online now
post #5 of 7 (permalink) Old 02-01-2019, 02:11 PM Thread Starter
After going through the Pontiac casting # book, 9799914 is a 1970 casting. I see a couple RAIII engines in Firebird and GTO with that casting # and 4 bolt main caps. Those are only in California engines which this engine is. ( Z code) I see lots of Grand Prix’s, Tempest, and Catalina’s with that casting # and 2bolt mains.
Bill E is offline
post #6 of 7 (permalink) Old 02-01-2019, 02:19 PM Thread Starter
If casting # 9799914 was used for 1970 RAIII engines with 4-bolt mains, does that mean all # 9799914 castings are drilled and tapped for 4-bolt mains? This motor might be worth something.
Bill E is offline
post #7 of 7 (permalink) Old 02-01-2019, 08:06 PM
Quoted: 59 Post(s)
Lots of Pontiac engines were drilled & tapped for 4-bolt caps, but came with 2-boit caps.
All the '70-'74 455's I built to race were that way.
If you run 2-bolt caps, the webs would be stronger if those extra holes were not drilled.
Some buy 4-bolt caps & have the block line honed or bored.
Some recommend putting bolts in the empty holes, to add a little strength, I suppose. I never had any block problems, at the 400hp/500 torque level.
bigD is online now
400 engine, weird pistons, strange object attached to cam! 1970PA4lifelemans 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 8 08-10-2018 05:42 PM
Strange Noise When Turning Off Engine - Balancer? peabody 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 05-21-2014 04:19 PM
Strange '65/66 frame code. Markd15668 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 12 11-06-2011 04:01 PM
Strange noise while braking hard? ftlfirefighter 2004-2006 GTO General Discussion 6 01-27-2006 03:08 PM
Radio Code and Key Code Card Darrin 2004-2006 GTO General Discussion 3 01-06-2005 10:42 PM
