TCS solenoid - Pontiac GTO Forum
post #1 of 2 (permalink) Old 12-10-2018, 07:21 PM Thread Starter
Quoted: 13 Post(s)
TCS solenoid
The Tcs solenoid on 1970 ram air is vacuumed from carb,but the 90 degree outlet is supposed to go back to vac advance on distributor?
If so do you not run vac advance to separate port on carb? Or is it teed at vac advance inlet at distributor?
Anybody?
rheckman is offline
post #2 of 2 (permalink) Old 12-21-2018, 08:48 AM
1968gto421's Avatar
Quoted: 70 Post(s)
Hopefully someone knowledgeable will see this and give you a hand with some good info.
If not, you could join the PY forum if you haven't already, and ask this there. there are two forums on the PY forum that might be of use to you. Best of luck with this.
70-72 GTO Tempest & LeMans TECH - PY Online Forums
Pontiac - Street - PY Online Forums
1968gto421 is offline
TCS Switch David Bluck Drive train, suspension, alignment and brakes. 0 03-24-2018 12:47 PM
P0335, TCS turns off, and crank/no start or start then die. dlb1982 Service, Maintenance and Technical Discussion 2 10-13-2015 09:57 PM
ABS and TCS fault and off, help! F4LL3NBURR1T0 Service, Maintenance and Technical Discussion 3 09-05-2012 02:01 PM
Power loss at 4k rpm + TCS off... HELP MoGoThnSho 2004-2006 GTO General Discussion 6 10-03-2009 11:49 AM
Feeler: TCS Memory Module KPierson Interior Discussions 1 06-23-2006 04:05 PM
