technical engine questions - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-02-2010, 07:15 PM Thread Starter
I have a 400 thats bored .040 over . The pistons are flat top with 12cc valve releifs how far off am I to be able to bolt on a set of 670 heads and run premium 93 octane . I like the way my engine runs good power for a cruiser it currently has 143 heads on it .I came across an excellant condition ready to bolt on pair of 670's for a deal that is very hard to pass up let me know if its worth the hassle
68gtohawk8369 is offline
post #2 of 5 (permalink) Old 10-02-2010, 07:23 PM
670 heads are real nice. They will bolt right up. 93 octane is kinda weak though. I AM NOT SURE ABOUT THE 12 cc THING so wait for more replies....
Eric Animal is offline
post #3 of 5 (permalink) Old 10-03-2010, 03:55 PM
Quoted: 117 Post(s)
The valve reliefs are pretty standard with flat top pistons, and won't significantly reduce your compression with 670's. 670 heads are one of the better Pontiac heads for high performance use, BUT are more prone to pinging and knock than most other heads. They are a closed chamber design like the earlier 421 heads. They typically cc out at 68 to 72cc. I think with your combo, running the 670 heads, you'd need about 98 octane fuel. Some folks have had moderate success at relieving the 670's a bit to open them up a few cc's, but this is highly specialized work and easily botched. My advice is to run a head with bigger chambers.
post #4 of 5 (permalink) Old 10-04-2010, 08:43 PM
646904GTO's Avatar
Do search for a thicker head gasket. I know a guy that got his compression down to 9.5 with them.
1969 400 T400 auto 2nd owner
1973 Challenger 360/727
1931 Ford Model A
646904GTO is offline
post #5 of 5 (permalink) Old 10-05-2010, 12:54 PM
66tempestGT's Avatar
if you buy heads with small chambers for more performance and then grind them out or use a thick gasket arent you back where you started? if you arent racing and you like the way it runs now seems like a waste of time.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
New to GTOs engine questions DM03 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 05-26-2009 01:31 PM
Engine ID questions 66GTO7.5L 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 15 04-20-2009 11:38 PM
Three questions re:'69 GTO engine and shifter suthin_man 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 05-22-2008 08:19 AM
67 GTO just arrive - Engine questions pwoolford 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 8 12-09-2007 06:06 PM
Technical question from a girl lisatw151 Service, Maintenance and Technical Discussion 20 12-03-2004 05:21 PM
