temp sender port - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-18-2018, 07:02 PM Thread Starter
Quoted: 33 Post(s)
temp sender port
I plan to put a separate gauge in for temp readings. I installed the stock temp sender in pass side of head for idiot light. I see my intake has a threaded hole in front. Is that a spot where a plug should go and I can use that for a sender? This motor was all apart when purchased and many things taken off.
Also, I plan to use a replacement fuel tank with return lines and vapor line. I have no vapor canister, but plan to use one. I assume I need a purge valve with all this? Where does that install?
tjs72goat is offline
post #2 of 3 (permalink) Old 01-18-2018, 09:18 PM
Quoted: 361 Post(s)
Temp sender can be installed in the intake. This is where most early engines had it installed. Later engines used the head.
I would think that a factory service manual will have the Emissions info for your car, but I found this on the Emissions. This might work for you.
Name:	01  Emmissions.JPG
ID:	102193   Click image for larger version
Name:	02  Emissions.JPG
ID:	102201   Click image for larger version
Name:	03  Emissions.JPG
post #3 of 3 (permalink) Old 01-20-2018, 08:31 PM Thread Starter
Quoted: 33 Post(s)
Thanks for the articles. Very informative.
D-port or Round port Headers Logchain 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 01-17-2017 11:33 PM
fuel sender 65gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-23-2014 10:08 PM
1970 GTO Temp Gages and sender OHGTOGEORGE 1964-1974 Tempest, Lemans & GTO General Discussion 0 02-02-2014 02:51 PM
66 389 temp gauge sender? Where?? thegangler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 03-07-2010 04:51 PM
