temp sending unit troubles - Pontiac GTO Forum
post #1 of 7 (permalink) Old 08-28-2015, 02:31 PM Thread Starter
my temp sending unit is pinned past the hot marker to where it is not visible. I removed the wire from the sensor and grounded it. with key on, needle goes to hot position. installed a new sensor, connected wire, need pinned past hot again. unit was working fine before I pulled engine to have it rebuilt. now that its back in?? well ,you know.....it never ends. any help is appreciated. thanks, tom
6t8goat is offline
post #2 of 7 (permalink) Old 08-28-2015, 04:10 PM
When you disconnect the wire with the key on does it go to cold?
post #3 of 7 (permalink) Old 08-29-2015, 12:43 PM Thread Starter
no. it is pinned past the hot. you can't see the needle. when I ground the wire it comes into view and stops at the "H".
6t8goat is offline
post #4 of 7 (permalink) Old 08-29-2015, 09:46 PM
Almost sounds like you've got a temperature switch in there (for a light) instead of a sending unit for a gauge...
post #5 of 7 (permalink) Old 09-07-2015, 04:23 PM
I think the idiot light switch/sensor has two terminals, where the gauge sensor has one?
JohnGoat is offline
post #6 of 7 (permalink) Old 09-07-2015, 05:13 PM
No sir, they both just have one connection. They only need one. The switch sensor is a simple off/on switch. When the coolant temp gets high enough, the switch closes a path to ground which turns on the light.
The temp sending unit is a resistor that varies in resistance value in proportion to engine temperature. It also connects to ground. What your temp gauge is actually reading is this resistance.
post #7 of 7 (permalink) Old 09-09-2015, 12:30 AM
I have a '70 with a 455. When I bought it, I was told it had the wrong temp sensor (it has idiot lights), it has the single terminal. I first tried to get an idiot light temp switch at Autozone, but all they showed was a gauge sending unit. I had them check earlier years and I think 68 or '69 listed an idiot light temp switch and it had 2 terminals. Since then, I believe I have figured out that the block is from a '74 or '75 Trans Am, with '67 428 heads on it. Not 100% certain. Anyhow, I left the gauge sending unit in it as I bought rally gauges, so I didn't check on the temp sensor situation with the '74/'75 455.
JohnGoat is offline
68 gto fuel sending unit wings012345 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 07-07-2015 08:33 PM
Temp sending unit ZackD1212 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-09-2015 05:57 PM
1970 gto Judge needs 3 prong temp sending unit qpb 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 06-13-2013 02:29 PM
Fuel sending unit Piedog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 04-09-2013 09:14 AM
What is the differance fuel sending unit 67 Lemans John 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 03-22-2008 03:49 PM
