TH350 kickdown cable - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-11-2018, 06:38 AM Thread Starter
Quoted: 23 Post(s)
I have the dual quads dialed in and am adapting the throttle bracket to accept the kickdown cable. My question is at what point in throttle should the cable pull out the kickdown? i am thinking just before full throttle? I set it long so i can use a crimp on the cable when i find the best spot.
Instg8ter is offline
post #2 of 3 (permalink) Old 07-18-2018, 02:58 PM
Quoted: 102 Post(s)
Most stock set ups kick down at WOT. So close, or at WOT should Git 'R Done.
post #3 of 3 (permalink) Old 07-21-2018, 10:57 AM Thread Starter
Quoted: 23 Post(s)
thanks GeeTee, i have been adding zip ties to the cable and driving to see when it will kick in. Even on freeway with the 2:56 rear end i don't get up much past 2000 rpm and know FULL throttle with the dual quads is something it won't see too often. That said i do want the auto kickdown coming in for passing even though i use the Dual gate often. Have 3 ties on and have not made it kick yet, as soon as i find the sweet spot ill crimp a ring or a hex collar on the cable.
Kickdown TV Cable Bracket swap to 200 4r hotcharity95 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 0 05-09-2016 08:03 AM
correct kickdown stud for edelbrock/th350 setup?? cardinal red 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 06-13-2013 10:54 AM
4bbl carb linkage and TH350 kickdown cable for '66 Lemans JB_Finesse 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 11-21-2012 11:46 PM
kickdown cable for turbo 350? virginiavenom 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 13 07-28-2011 08:20 AM
1971 Lemans kickdown cable rcauchon 1964-1974 Tempest, Lemans & GTO General Discussion 1 08-13-2010 10:22 PM
