TH400 in a 65 GTO - Pontiac GTO Forum
post #1 of 5 (permalink) Old 12-04-2017, 10:06 AM Thread Starter
TH400 in a 65 GTO
Does anyone know if the trans cooler lines from a 67 will fit my TH400 in a '65?
Thanks.
Dick Steinkamp
Bellingham, WA
Dick Steinkamp is offline
post #2 of 5 (permalink) Old 12-04-2017, 10:40 AM
The '67 GTO T400 lines should work, have never noted a difference in the location of the trans cooler line fittings in the lower tank. Several years back was organizing & stripped the Harrison tanks & steel rails out of dozens of original GTO & Firebird radiators.
post #3 of 5 (permalink) Old 12-04-2017, 11:01 AM Thread Starter
Thanks, PH.
How about the length?
Dick Steinkamp
Bellingham, WA
post #4 of 5 (permalink) Old 12-04-2017, 11:44 AM
The length won't be effected as the lines exit the side of the T400's case. The diffence in length between short tail T400's & long tail T400's is in the tail shaft housing, the longer output shaft, & having a further back trans mount. Since the '64-67 A-bodies have a 116" wheelbase, it's possible the swap will not effect pinion angle as much as it would in a later 112" A-body. On the '68-72 A-bodys, I've had to resolve the mess of a previous long tail T400 rig jobs, as the fans were getting into the bottom of the fan shroud, as well as the resulting pinion angle was off. Correct length T400 is def the way to go, esp on later (shorter wheelbase) cars.
BTW, On kickdown switch addition, i looked up '67 pedal rod, & it is the same as '66 models. without having a '65 pedal assembly next to a '66-67, not able to compare the contour of the rods.
post #5 of 5 (permalink) Old 12-04-2017, 01:23 PM Thread Starter
Thanks. I'm going to order the hard lines. Currently using hose. Not very comfortable with that!
Dick Steinkamp
Bellingham, WA
Any Advice? - swapping TH200R4 for TH400 - 69 GTO Heatwave 1964-1974 Tempest, Lemans & GTO General Discussion 42 05-01-2019 01:33 PM
1964 GTO TH400 interchange ? sci-flyer 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 0 11-01-2016 12:14 PM
67 GTO TH400 data tag drburns 1964-1974 Tempest, LeMans & GTO Data Plate, Vin Tag and Drive Train Numbers 9 05-23-2016 07:41 PM
Th400/700r4 conversion 70 gto DOMINICK Gtoforum.com Site Help 1 06-27-2015 07:12 PM
68 GTO TH400 Crossmember issue JamiesGTO 1964-1974 Tempest, Lemans & GTO General Discussion 0 11-03-2013 05:39 PM
