Thermostat gasket dressing - Pontiac GTO Forum
post #1 of 5 (permalink) Old 05-25-2019, 06:14 PM Thread Starter
joelau27's Avatar
Quoted: 5 Post(s)
What is the preferred gasket sealer for thermostat gasket, not form a gasket?
joelau27 is offline
post #2 of 5 (permalink) Old 05-25-2019, 07:58 PM
BLK69JUDGE's Avatar
Quoted: 42 Post(s)
I really like
https://www.permatex.com/gasket-maker-comparsion-chart/
the right stuff in gray and or black
its the bomb works great with a gasket ....
BLK69JUDGE is online now
post #3 of 5 (permalink) Old 05-27-2019, 07:42 PM
Lemans guy's Avatar
Quoted: 40 Post(s)
My favorite is the copper gasket sealer. You use it with a gasket and the loose copper fills in all the minute imperfections. It is the only one That I have never had leak.
Works great on thermostats and water pumps and all seals. All the auto parts have them permeated and others make it.
Lemans guy is online now
post #4 of 5 (permalink) Old 05-27-2019, 07:48 PM
Lemans guy's Avatar
Quoted: 40 Post(s)
Here is a name of one...K&W copper Coat Gasket Compound...it has an applicator and you brush it on the gasket or surface.
It really seal it up and resists high temp, it is copper colored, so clean off the excess.
post #5 of 5 (permalink) Old 05-30-2019, 08:17 AM
Bob Young's Avatar
I've always used spray trim adhesive on all gaskets. I spray both sides of the gasket and the mating surfaces, wait until tacky then assemble. On a thermostat I put the thermostat in the manifold, then gasket to hold the tstat in the proper position, then the neck. Torque the bolts to the proper spec and you're good to go. Never was a fan of silicone adhesive.
Not a Amazon fan but here's what I use;
https://www.amazon.com/3M-08074-Spra...gateway&sr=8-3
Bob Young is offline
Cleaning up and dressing up the engine Orion88 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 11-04-2013 06:59 PM
Slp 160-degree thermostat Gertythadirtygoat Engine Discussions 1 06-03-2007 04:54 PM
Thermostat gasket GOAT06 Service, Maintenance and Technical Discussion 0 03-26-2007 07:52 PM
160* thermostat stangeater 2004-2006 GTO General Discussion 14 02-23-2006 08:26 PM
