Thermostats 64 GTO - Pontiac GTO Forum
 1Likes
  • 1 Post By geeteeohguy
post #1 of 6 (permalink) Old 07-02-2018, 06:11 PM Thread Starter
Quoted: 4 Post(s)
Thermostats 64 GTO
Do you need to remove the water pump to change the thermostat ?
Theda Pretsell is offline
post #2 of 6 (permalink) Old 07-03-2018, 08:45 AM
Quoted: 126 Post(s)
No it is between the intake manifold and the water neck / thermostat housing (this is what it looks like https://www.ebay.com/itm/1964-70-Pon...-/271410512426).
Drain your radiator fluid entirely or enough that the level is below the thermostat, remove the upper radiator hose, remove the thermostat housing, and replace the thermostat. You may want to use silicone around the edge to help seal....
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
post #3 of 6 (permalink) Old 07-03-2018, 07:49 PM Thread Starter
Quoted: 4 Post(s)
Thanks for the info but my car is a 389 tri powered intake
post #4 of 6 (permalink) Old 07-03-2018, 10:05 PM
Quoted: 363 Post(s)
What does your 1964 Service Manual say on how to remove it?
post #5 of 6 (permalink) Old 07-04-2018, 09:20 AM
Quoted: 126 Post(s)
Not sure your point.....I just showed you a thermostat housing so you could understand where the thermostat was located on your car. Based upon your initial question, it appears you are unsure of where / how to replace a thermostat (since it is not located near/with the pump).....
Here is a picture of a 64 GTO tri power thermostat housing https://www.opgi.com/gto/GTH0010/
Current setup:
4 speed Muncie
post #6 of 6 (permalink) Old 07-06-2018, 01:15 PM
Quoted: 99 Post(s)
Why would you want to remove the water pump to replace the thermostat? That's like removing the headlamps to replace the tail lamp bulbs. Makes no sense at all. Both the 3x2 and 4v T-stat housings are easy to remove by undoing the two bolts that hold them in place. Ten minute job.
cij911 likes this.
69 gto disc brakes on a 64 gto iamthehans 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 02-18-2016 12:36 PM
New to Forum, '64 GTO and '66 GTO BriKamFer Member Introductions 2 05-14-2015 03:54 AM
will a 65 gto rear bumber fir a 64 lemans gto lew64 1964-1974 Tempest, Lemans & GTO General Discussion 3 08-17-2011 08:23 PM
Winter / Summer thermostats daveh70 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 12-17-2009 07:56 PM
