Throttle cable - Pontiac GTO Forum
post #1 of 1 (permalink) Old 04-19-2018, 04:34 AM Thread Starter
Throttle cable
I have a 68 GTO I purchased about a year ago. The car hadn't run since 1999 do to several wires that melted in the engine wiring harness. I ordered a new wiring harness from OPGI to accommodate an MSD ready to run distributor and an internally regulated alternator. I also changed the Qjet Carb for an Edelbrock Thunder Series AVS 800 CFM carb. That's where my problem started. The Edelbrock is wider than the Qjet and the throttle linkage doesn't align correctly and I'm not able to get full travel on the throttle. I did some research and found Edelbrock makes a linkage adapter for Pontiacs that run Edelbrock intakes (mine has the original TORQ). The instructions say to cut the original throttle cable bracket and install the adapter. I really don't want to cut the original bracket (even though they make reproductions) if I don't have to.
If any has come across this in the past and has a work around that works (by works, I mean flawlessly) please let me know. Any suggestions would be greatly appreciated.
PS. after about 3 afternoons of working on the car it was running just fine after 19 years.
Dean
Name:	new carb installed (1).jpg
ID:	108730   Click image for larger version
Name:	edelbrock linkage adapter.jpg
ID:	108738   Click image for larger version
Name:	new carb installed (2).jpg
Akhuntr is offline
Throttle cable bullet20cc 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 04-28-2016 08:52 PM
throttle cable and bracket help WhittP 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 04-19-2014 08:01 PM
Stretched throttle cable? xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 11-10-2013 10:20 PM
throttle cable Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 2 10-09-2011 08:54 PM
throttle cable Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 2 03-06-2011 04:25 AM
