Tripower intake crack - Pontiac GTO Forum
post #1 of 5 (permalink) Old 08-10-2018, 08:20 PM Thread Starter
Quoted: 4 Post(s)
I'll post a picture later to show exactly what I'm talking about, but the '66 tripower intake I have has a crack at the water temperature sending unit threads. It extends from the threads about 1/4-3/8". It's been years since this intake was in service and it didn't leak then, but as I move forward with this build, I want to take care of these kinds of things before they become a problem. Should I try to remedy this now or not worry about it? What's the chance a crack like this grows? Is there even a way to fix it?
TriPower65 is offline
post #2 of 5 (permalink) Old 08-11-2018, 08:32 AM
Quoted: 126 Post(s)
Not sure if you could really fix it. The part is cast. Maybe you could try applying a sealer (liquid metal or whatever it is called), letting it cure, sand, and then paint. I would probably just pick one up at a swap meet or buy a new aluminum one from John @ Pontiac Tri Power.
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is offline
post #3 of 5 (permalink) Old 08-14-2018, 03:08 PM
Quoted: 98 Post(s)
It could be fixed. Look up metal stitching. Probably easier and cheaper to get a replacement intake. '66 units are also known for cracking inside around the center carb, due to the choke set-up this one year used.
post #4 of 5 (permalink) Old 08-14-2018, 09:43 PM Thread Starter
Quoted: 4 Post(s)
Exhibit A
post #5 of 5 (permalink) Old 08-25-2018, 02:14 PM
Quoted: 98 Post(s)
If it's not leaking coolant, I'll bet you could run that intake another 50 years just the way it is.....
HARd Crack sound rear end Bossin Service, Maintenance and Technical Discussion 4 09-08-2011 04:02 AM
06 Goat W/ Radiator Crack. 45kmiles 06SixOhGoat Service, Maintenance and Technical Discussion 15 05-27-2011 09:10 PM
crack monkey crack monkey Member Introductions 2 06-23-2007 01:34 PM
California to crack down on modified cars fergyflyer Service, Maintenance and Technical Discussion 18 08-07-2005 04:34 PM
