Two temp senders - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-08-2018, 04:27 PM Thread Starter
Quoted: 33 Post(s)
Two temp senders
I have idiot lights in my 72. I will run the stock blade type sender in the head where it should be. I also want to set up a set of gauges. So, is the best place to put the button style sender for a gauge in the intake? I assume I don't need that for the purge valve if I don't want to plumb that, even if I use the evaporator canister for emissions?
tjs72goat is offline
post #2 of 3 (permalink) Old 03-08-2018, 06:05 PM
Quoted: 106 Post(s)
There is a flat spot on the driver's side of the manifold next to where the thermostat goes.
That spot can be drilled and tapped with a 1/2 in. pipe tap for the gauge sender.
Goat Roper is offline
post #3 of 3 (permalink) Old 03-12-2018, 06:38 PM Thread Starter
Quoted: 33 Post(s)
Thanks.
Operating Temp devildawg 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 09-24-2014 05:41 PM
temp gauge harobikes1988 2004-2006 GTO General Discussion 0 01-10-2012 05:38 PM
engine temp Topkat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 9 04-28-2011 12:58 PM
06 running temp BaadFLGoat 2004-2006 GTO General Discussion 5 11-25-2010 08:57 AM
temp gauge one a 67 wytnyt 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 06-04-2008 06:48 PM
