Under Hood Light Directions - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-26-2018, 10:08 PM Thread Starter
Quoted: 11 Post(s)
Hello,
Does anyone have the directions as to placement of the underhood light and the switch for a
1967 GTO. Also, I'd like to know how they are supposed to be finished, Both the light, the switch and
Bracket for the switch. What colors are the wires supposed to be?
Sixty7GTO is offline
post #2 of 3 (permalink) Old 09-27-2018, 04:21 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
This is a '65-'66 SW so not sure if anything changed for '67. I do not believe so.
Wire is Black.
The single feed line from the engine harness is just about center of engine/firewall.
Connectors are White (Yellowish).
Light housing was painted Black, Less the bulb area.
Bracket was painted Black as well.
OE switch in '65 & '66 had a metal housing, this may differ for '67?
(Most of the Re-Pro kits utilize a Plastic Brake light switch now)
Placement is approx center of the engine/firewall just about split of firewall seam.
(There are Factory Guide "Dimples" in the firewall to help alien the Bracket & Switch mounting holes,
these are not always perfect but should help)
The light shown below is on my '66 OHC car but would be as any A-Body model.
ID:	115605   Click image for larger version
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #3 of 3 (permalink) Old 05-05-2019, 02:07 PM Thread Starter
Quoted: 11 Post(s)
Thanks for the information.
LS2 Rough Idle and surging under light accereation Hwy Goat Service, Maintenance and Technical Discussion 2 12-24-2016 06:07 PM
push button under the hood aarons1k 2004-2006 GTO General Discussion 10 09-14-2008 07:58 AM
Trans Lock Lever Under Hood? powerman_dsr 2004-2006 GTO General Discussion 3 03-01-2006 08:17 AM
Could this be under Steve's hood? johnebgoode 2004-2006 GTO General Discussion 2 01-13-2006 11:29 PM
Holes on silver bezel under right side of steering wheel under gauge cluster? hssaini 2004-2006 GTO General Discussion 9 12-29-2005 10:07 PM
