Valve guides in 400 H.O #16 heads, another stone in the shoe - Pontiac GTO Forum
post #1 of 2 (permalink) Old 02-06-2013, 05:08 PM Thread Starter
fredyG's Avatar
In the difficult road to restration you always need to investigate, search, ask for advise and get desesperate well... were in the world I can buy valve guides for my 68 400 H.O #16 head-ache. (Sealed Power ZVG5002 in Sumitt??) only exhaust, but the same guide be good for V6-V8s and a dozen more engines?? There is a photo of my guides. Thanks
Name:	2 Diferent Valve Guides .jpg
fredyG is offline
post #2 of 2 (permalink) Old 02-07-2013, 01:10 PM
lars's Avatar
Factory iron heads don't have replaceable guides. To install new guides, the guides are purchased by ID/OD and the head is machined to take the new guides. That means machining off the existing guide bosses and pressing in the new bronze guides. The existing guides can also be reamed for "K-Liners" which are much thinner than "normal" bronze guides.
Yes, the guides are universal for a wide range of engines, and are then trimmed to length to fit your heads, along with the heads being machined to accept the guides. This isn't something you can do at home...
Lars
lars is offline
32 valve heads! dustyminpin The Lounge 3 08-22-2010 11:37 AM
Changing Valve Spring w/0 Removing Heads gurvinerjeff Engine Discussions 6 02-18-2010 01:08 PM
??CHANGING VALVE SIZE '69 #16 heads?? bigcode99 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 2 01-26-2007 05:54 PM
??changing valve size '69 #16 heads?? bigcode99 Engine Discussions 0 01-22-2007 07:33 PM
pontiac heads - seats & valve stem seals gman26 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 01-25-2006 12:48 PM
