Washer pump - Pontiac GTO Forum
post #1 of 2 (permalink) Old 04-16-2019, 04:54 PM Thread Starter
Washer pump
Hi All
I took the windshield washer motor out when I painted the engine bay. After installing the washer motor, the wter pump didn't work. I changed it and same thing. I hear it ticking but no water comes out the nozzles. I checked the washer bottle, hose, and nozzles. Everything fine. Don't know what's going on?
Aziz2010 is offline
post #2 of 2 (permalink) Old 04-17-2019, 04:39 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
Sounds like something fell out of alignment. If your sure it was working before?
You need to carefully remove just the pump and check the Ratchet/Wheel, Pump arm and Motor Cam.
Be mindful of the Cam (Little Star shaped piece)as it sometimes falls off.
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
66 washer pump drive gear stevebrochu 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 08-15-2012 06:47 PM
Rebuilt washer pump but still nothing danthepontiacman 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 06-08-2012 01:07 PM
70 Lemans washer pump wiring docmark1 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 04-25-2011 10:06 AM
