Water Pressure in Radiator - Pontiac GTO Forum
post #1 of 2 (permalink) Old 01-08-2019, 05:56 AM Thread Starter
So...im not Mechanic but try my best to do as much as i can by myself...Theres the Problem:
I bought a 65 in Dezember 2017, when i was there to look at the car i popped the Hood and opened the Radiator Cap...Boom...the car was Cold but there was A LOT of Pressure in it.
Didn`t mind...bought the Car, drove it the whole last Year. Temperature was never higher than 190 F ( I got an Aluminium Radiator and a Big and two small Electric Fans).
A few Days ago i opened the Radiator Cap and the Same Thing happened. A lot of Pressure in the Radiator. Now i checked the Termostate, this one is completely Stuck.
Now could this be the only Reason? Heard thet a bad Head Gasket could cause this Problem too...but the Car runs perfect and i don`t have any Water in Oil.
ManuelB is offline
post #2 of 2 (permalink) Old 01-08-2019, 08:20 AM
Quoted: 126 Post(s)
Remove the thermostat or replace with a working 160 - 180* (you choose) and you should find you are fine.....
Current setup:
400 cu in with tri-power
4 speed Muncie
cij911 is online now
'72 GTO oil pressure / water temp guage wiring Chooko 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 09-21-2018 10:44 PM
65 water temperature and oil pressure gauge problem cij911 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 06-29-2018 10:39 PM
1967 GTO factory radiator cap pressure rating jbach 1964-1974 Tempest, Lemans & GTO General Discussion 6 08-27-2014 04:36 PM
No pressure in upper radiator hose trimfixer 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 07-12-2011 03:10 PM
Sounds like water boiling in radiator. Lowe48_03 Service, Maintenance and Technical Discussion 5 11-15-2009 11:21 AM
