Water Pump/Timing Chain Housing repair? - Pontiac GTO Forum
 3Likes
  • 1 Post By GotTogO
  • 2 Post By bigD
post #1 of 3 (permalink) Old 11-05-2017, 04:01 PM Thread Starter
Donny Nelms's Avatar
We have a Pontiac 350 from a 1974 car in our 1967 Le mans. When the car was parked 20+ years ago it had cooling issues and ran hot. My Father-in-law built the car for my wife when she was in high school. They ran the car for about 5 years before it overheated and burped water. Recently we started working on the car and decided to pull off the water pump. 3 of the bolts broke off that held the pump to Housing. We have tried to use a Easy-out type screw extractors , sprayed them down with several types of Liquid wrench as well as adding heat to the broken bolts to try and break them free. we managed to get one out but it damaged the ear on the housing. It has2 more we are afraid to try and get out. The Housing i believe is cast aluminum.
Is there a way to repair these holes if we screw up the remaining 2 holes or just try to find a new Housing. We would like to get the car in driving shape and possibly do a rebuild and few years down the road. The car needs floor pan work before it can be seriously driven but can be easily moved by driving it.
Donny Nelms is offline
post #2 of 3 (permalink) Old 11-05-2017, 05:15 PM
Helicoil?
Have you tried drilling them out?
Donny Nelms likes this.
GotTogO is offline
post #3 of 3 (permalink) Old 11-05-2017, 06:12 PM
Quoted: 59 Post(s)
New timing covers are available. Don't know of the quality of any of 'em. Some come with new tubes & a divider plate, some don't.
https://www.ebay.com/itm/NEW-TIMING-....c100005.m1851
https://www.summitracing.com/parts/a...hoCb2gQAvD_BwE
http://www.krepower.com/Pontiac%20Timing%20Covers.htm
https://butlerperformance.com/i-2445...tegory:1234742
https://www.ebay.com/itm/Pioneer-Pro...pZ51L3&vxp=mtr
https://www.summitracing.com/parts/pio-500-455
Can also probably buy a good used cover, on one of the Pontiac forums.
1968gto421 and Donny Nelms like this.
bigD is online now
1966 gto 389 water pump internal housing tonyli 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-28-2014 07:57 PM
Water pump housing orelog 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 06-07-2014 03:13 PM
Timing Chain Covers/water pump mmag36 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 08-15-2012 09:24 AM
Water Pump Housing the65gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 01-16-2012 09:40 AM
timing chain studs Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 03-06-2011 12:55 AM
