What Holley carb? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 09-04-2018, 02:20 AM Thread Starter
Quoted: 5 Post(s)
What Holley carb?
Can someone please tell me what model this Holley carb is? It's on a 69 GTO
I need to get a proper throttle cable bracket for it. The original cable bracket has my pedal half way to the floor.
Thanks.
Please let me know if you need more photo's.
ID:	115265   Click image for larger version
ID:	115267   Click image for larger version
ID:	115269   Click image for larger version
Jimsgoat is offline
post #2 of 7 (permalink) Old 09-04-2018, 10:59 AM
Quoted: 55 Post(s)
The model number is stamped on the front of the choke tower. None of the pics you posted show this number. In this link, you can click on an enlargement & see that this is a model #1850
https://www.summitracing.com/parts/hly-0-1850s
If your throttle cable is too short, just add an extension to it. You can either make one or buy one.
https://www.summitracing.com/parts/e...hoCmmwQAvD_BwE
https://www.oreillyauto.com/detail/b...e/8012/4289404
https://goo.gl/images/6r7RVD
bigD is offline
post #3 of 7 (permalink) Old 09-04-2018, 09:20 PM
Fitting a Holley can be somewhat of a pain, as I've been finding out here lately. I found out trying to get the throttle cable fit to the one I'm running now that none of the available holes in the carb throttle arm were the same distance from the throttle shaft as the one on my QJet. This matters because this distance in conjunction with the amount of travel available on the cable is what determines things like pedal position and also whether or not you have enough travel to move from idle all the way to full throttle. I wound up taking this measurement off my QJet and then using it to drill a new hole in the throttle arm on the Holley that was the same distance from the throttle shaft center line. That took care of my problem.
BearGFR is online now
post #4 of 7 (permalink) Old 09-04-2018, 09:58 PM
Quoted: 31 Post(s)
I had similar issues. Lots of trial and error. Try searching PY site as my 68 with pictures are on it. We ended up doing some fab work on bracket . It just take time snd patients . Doug
dd68gto is offline
post #5 of 7 (permalink) Old 09-05-2018, 02:20 AM Thread Starter
Quoted: 5 Post(s)
Thanks guys, the numbers on the choke tower are in the photo attached. I guess the carby is a 4160.
My throttle cable is about 1 inch too long and as such the throttle pedal is alway half way to the floor at idle.
The other photo is a ready available "adjustable" bracket for the 4106 and 4105 holleys. Has anyone tried this bracket and is there enough adjustment?
A few of the brackets I've seen advertised do have the dimension. So I might measure around the carby and see if it will fit.
Thanks again
Jim
ID:	115279   Click image for larger version
Jimsgoat is offline
post #6 of 7 (permalink) Old 09-05-2018, 08:19 AM
Quoted: 55 Post(s)
That 80457 number appears to be a 600cfm model.
https://www.holley.com/products/fuel...xoCdEAQAvD_BwE
There are lots of different types of throttle brackets.
https://www.google.com/search?q=thro...hrome&ie=UTF-8
But, I suspect the best method is to mod your particular set-up, as mentioned by these other guys. Most every drag car I've built needed throttle linkage/bracket/cable mods.
bigD is offline
post #7 of 7 (permalink) Old 09-05-2018, 06:24 PM Thread Starter
Quoted: 5 Post(s)
Thanks bigD. I might measure up for one of the adjustable brackets. They're quite cheap. If it doesn't fit I'll modify the existing.
Jimsgoat is offline
70 GTO & Holley carb dies around turns or braking michaelrj9 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 6 02-08-2016 06:14 PM
Holley carb on Carter intake? Mr_Roboto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 07-19-2013 02:22 PM
67 Gto Holley Red Pump Location mmag36 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 03-22-2010 03:54 PM
Holley 750 Double Pumper or Vacum secondary??? deze2000 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 10-30-2009 03:39 PM
