Windshield washer bottle location on a 1967 GTO - Pontiac GTO Forum
post #1 of 10 (permalink) Old 03-13-2018, 12:47 PM Thread Starter
A picture of the correct bottle and cap and location would be helpful.
Andrew69 is offline
post #2 of 10 (permalink) Old 03-13-2018, 01:27 PM
Quoted: 106 Post(s)
It goes on the driver's side fenderwell.
The reproduction Ames carries lines up with the holes.
Name:	GTO Part Deux 011.jpg
Goat Roper is offline
post #3 of 10 (permalink) Old 03-13-2018, 01:35 PM
Quoted: 106 Post(s)
Couldn't find it @ Ames, OPGI has it, cap sold separately.
https://www.opgi.com/gto/G240407/
post #4 of 10 (permalink) Old 03-13-2018, 03:33 PM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
Are you referring to the plastic WW fluid JUG or the WW concentrate glass Bottle?
Also note the jug came as an early build (short '66 style) and late (Taller) most widely used version.
Cheers
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #5 of 10 (permalink) Old 03-13-2018, 06:04 PM Thread Starter
Interesting. How does one determine early or late? Trim tag or VIN?
Andrew69 is offline
post #6 of 10 (permalink) Old 03-13-2018, 06:24 PM
Quoted: 106 Post(s)
Click on the center pic in the OPGI link see the kitty corner mounting holes?
Look on your fenderwell for those holes.
My '67 was put into service May 7th 1967 and is a February build and has the plastic bottle.
The repro bolted right up to the factory holes.
post #7 of 10 (permalink) Old 03-13-2018, 07:07 PM Thread Starter
This car has two holes in the inner fender that would be opposite corners of a square.
Per the trim tag it is a 05A build, so late in the model year. So it should have the black plastic bottle. Correct?
Andrew69 is offline
post #8 of 10 (permalink) Old 03-13-2018, 07:18 PM
Quoted: 106 Post(s)
Yup that is the correct bottle for your goat.
post #9 of 10 (permalink) Old 03-14-2018, 04:38 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
Had to double check on the short Vs Tall jugs for '67 as it's been awhile.
Just as an FYI it seems to be associated with CA smog '67's
I thought it was a mid year change but,
Literature indicates the smaller white plastic jug with bracket was used with SMOG cars and mounted on the RH core support.
So your good with the Taller Jug.
post #10 of 10 (permalink) Old 03-15-2018, 07:26 PM Thread Starter
Today received the jug and associated parts. It looks good.
Thank you,
Andrew
Andrew69 is offline
Windshield washer bottle location on a 1969 GTO Road Rat 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 7 02-06-2016 06:11 PM
Correct washer bottle color 6t8goat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 08-27-2015 10:14 PM
1965 GTO windshield washer line routing help needed Jjkra 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 4 09-24-2014 02:57 PM
68 GTO Windshield washer hose routing FlambeauHO 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 7 12-10-2013 03:05 PM
67 Washer Bottle and Bracket mysweet67 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 9 09-11-2012 10:48 PM
