Wire Harness or Vacuum line Straps - Pontiac GTO Forum
post #1 of 6 (permalink) Old 12-27-2018, 04:10 PM Thread Starter
joelau27's Avatar
Quoted: 8 Post(s)
Hello Happy New Year to everyone,
Looking for wire straps that are mounted on the inner fender well on the drivers side for a '69 GTO. Mine are approx. 5.5 inches long, can't seem to find this length anywhere.
does anybody have a source for this length strap?
Thanks,
Joe
joelau27 is offline
post #2 of 6 (permalink) Old 12-27-2018, 05:03 PM
Quoted: 367 Post(s)
post #3 of 6 (permalink) Old 12-27-2018, 06:24 PM Thread Starter
joelau27's Avatar
Quoted: 8 Post(s)
Still a little short, thanks Jim.
joelau27 is offline
post #4 of 6 (permalink) Old 12-27-2018, 08:51 PM
Quoted: 367 Post(s)
OK, how about these? 7" total length and can be trimmed. https://www.ebay.com/i/222635522884?chn=ps which appears to be the same as these - https://www.ebay.com/itm/GM-Wiring-H...-/142727701621
I did not seem to be able to find anything else close to your size, generally shorter in length.
post #5 of 6 (permalink) Old 12-28-2018, 05:20 AM
GTOJUNIOR's Avatar
Quoted: 64 Post(s)
Can't say I've seen wire straps longer then 4.5 but you might check;
https://www.clipsandfasteners.com/default.asp
https://mrgusa.com/fasteners/
GTO Jr. - A.K.A. SPRINT 6
GTOJUNIOR is offline
post #6 of 6 (permalink) Old 12-28-2018, 09:54 AM Thread Starter
joelau27's Avatar
Quoted: 8 Post(s)
MIne are 5 inches long. The GM part # is 3848472. They need to hold 2 vacuum lines. The one closest to the battery has the pos. cable running through it, according to the assembly manual.
joelau27 is offline
69 Vert Ralleye Gauge Ground straps Mark8117 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 08-01-2018 07:28 PM
Ground Straps alanmay0 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 09-11-2016 02:35 PM
70 GTO Ground Straps sweet70gto 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 0 10-24-2014 11:06 AM
68 GTO Body Ground Straps & Ignition Coil ?? stuntmanw 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 09-09-2014 12:37 PM
