WS vs WT Engine code for '68 GTO - Pontiac GTO Forum
post #1 of 4 (permalink) Old 08-06-2012, 11:32 AM Thread Starter
Can somene help me locate the engine code for a 68 GTO (4 speed). I have to know if it is WS or WT because I am replacing the carburator and I order either a Rochester 7028263 or 7028267. It might be an HO engine but not sure. If there is any other way to find out besides engine code please advise. It has a 4 barrel on it now but from a '70 GTO. A picture would be very helpful.
Thanks,
Al M.
Al M is offline
post #2 of 4 (permalink) Old 08-06-2012, 11:47 AM
68GTO4004Spd's Avatar
WS is H.O., WT was standard 400. Look at the front of the engine on the passenger side, just below the head. They are about 1/4" tall and not stamped very deep, sorry no pic.
68GTO4004Spd is offline
post #3 of 4 (permalink) Old 08-06-2012, 11:52 AM
I'm not sure what you're asking for... WS and WT are both valid codes for a 68 GTO with a manual transmission.
Are you wanting to know where to find the code on the engine? Here's a reference:
How to identify your Pontiac engine
To positively id a Pontiac head or block, always start with the date code to identify the model year before progressing on to the other codes. Pontiac used the same 2-character block code to designate completely different engines in different years.
post #4 of 4 (permalink) Old 08-06-2012, 03:04 PM
Quoted: 118 Post(s)
Check the letter code, as stated. Easy to see. Also, HO engines will have an open element air cleaner, the special exhaust manifolds, and the positive battery cable will be going along the front side of the engine mount, not between the last two cylinders thru the exhaust manifold on the driver's side.
Engine code SR85542 on 66 GTO dgoat8u 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 5 12-15-2011 10:22 PM
326 XF engine code 67lemans 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 01-31-2010 09:41 PM
Engine Code X4??? Lukeduk1980 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 29 06-28-2009 05:38 PM
need a little engine code help excessive 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 06-03-2009 07:17 PM
Engine code POOF 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 06-20-2008 10:32 PM
