66 GTO Grille Paint - Pontiac GTO Forum
post #1 of 6 (permalink) Old 01-31-2011, 03:24 PM Thread Starter
gtoearl's Avatar
66 GTO Grille Paint
Hi Guys,
My 66 GTO is now in the paint shop getting Blue Charcoal. I'm going to re-paint the Grilles as I can't afford new one. What color gray paint and Manufacture should I look for? Also, the Black Grille paint? While I'm at it, I'm also going to re-paint the engine compartment it's correct Black. What color and Manufacture for that also. Thanks again for all your help. This site is a special tool I've come to rely on.
gtoearl is offline
post #2 of 6 (permalink) Old 01-31-2011, 03:56 PM
Quoted: 20 Post(s)
grille sides are argent silver and engine and grilles are 60% gloss black (satin) i believe...least thats what i did mine.
1966 Tempest pictures by instg8ter - Photobucket
Brian
Instg8ter is online now
post #3 of 6 (permalink) Old 01-31-2011, 04:56 PM
Originally Posted by gtoearl View Post
Hi Guys,
I used Eastwood paints. Their Underhood black is the correct 60* paint for under the hood. I used it on the firewall inner fenderwells, the filler on top of the radiator the radiator shroud. I used their ultra black chassis paint for the chassis areas and a-arms sway bars etc. Beneath the car on the chassis I used their Rust Encapsulator. While their paint is not cheap its the best paint I ever used.
You can also try NAPA. NAPA's underhood black is made by Martin Senour. That paint isn't too bad but its more satin than the semi-gloss 60* paint of Eastwoods. Duplicolor isn't a bad paint to use either.
Little "glarie" but the back of the grilles I restored is flat black and the sides are 60* black
post #4 of 6 (permalink) Old 02-02-2011, 01:21 AM Thread Starter
gtoearl's Avatar
GTO Grille....
Thanks to all that have helped me with this question.........I still remain a little confused. My grille looks more like gray than silver and the front grate pattern is a black color, maybe a flat black. I've looked at the Eastwood paints and can't find a description of what would be the correct color for my 66 GTO.
gtoearl is offline
post #5 of 6 (permalink) Old 02-02-2011, 05:58 AM
They silverish gray look like the same argent color on the '70's. Check in to the Argent wheel paint color. I believe that argent and the color of the surround are the same color, at least they appear to be in pictures I have seen.
1966 gto grilles,grills,4 budget restoration,easy fix! - eBay (item 280622858103 end time Mar-01-11 04:45:36 PST)
post #6 of 6 (permalink) Old 02-02-2011, 06:12 PM
Quoted: 20 Post(s)
it's argent silver surround (sides) with flat black grates
2005 gto grille options scottmmckinney Exterior Discussions 6 09-27-2010 03:23 PM
gto grille D Anderson 2004-2006 GTO General Discussion 0 08-19-2009 07:05 PM
04-06 OEM GTO Inset Sport Grille chucksgto Interior Discussions 8 01-24-2009 02:43 PM
